Which high flow cat for gtm tt kit?
Old Nov 26, 2012 | 06:32 PM
lp_turbo's Avatar
lp_turbo
Originally Posted by rcdash
You will lose a lot more horsepower putting them right after the turbos. My experience was 60 vs 20 whp loss (moving them further back). They work much better lighting off up close though.
I want more info about that !?
Old Nov 26, 2012 | 07:15 PM
Elperuano's Avatar
Elperuano
With it being so close to turbos does it make more susceptible for the TP or HFC to burn up quicker?
Old Nov 27, 2012 | 04:50 AM
rcdash's Avatar
rcdash
I have never had an issue with melting (metal) cats even running right after the turbo - have always had a properly tuned car. In boost, the AFR drops, but how long can you stay in it? I'm sure the cats get hot with AFRs in the low 11s, but most of the time, you'd be cruising at 14.7 just like any other car.
Old Nov 27, 2012 | 04:00 PM
lp_turbo's Avatar
lp_turbo
RCdash
HFC melting isn't my concern, i want more info on delta 40whp you said in previous post...
I want to know if you loss 40whp only at lower rpm because turbos take more time to spool or if you loose it everywhere on power band? And i want to know if your setup are the same before and after hfc moving?
Dyno sheet?
Old Dec 1, 2012 | 05:38 PM
rcdash's Avatar
rcdash
replied to your PM. You lose power everywhere with cats. My setups did change quite a bit when I moved my cats further back, but has been true dual 3" exhausts the entire time.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
