SEXY Girl doing 500-600whp turbo build!!!
Old Mar 5, 2013 | 02:22 PM
  #181
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by str8dum1
theres nothing wrong with the TN gate. the old piping style cracked. with the new piping you can recirc it just fine. or you can run it open. but no reason to waste money on a new gate
Contrary to your opinion, there was also a history and reputation for problems with boost spikes. Those who swapped out the wastegate seemed to resolve that issue IIRC.
Old Mar 5, 2013 | 03:00 PM
  #182
Resmarted's Avatar
Resmarted
Yeah I remember something similar too. I think it was the angle the pipe was on combined with the gate size. If the location was more efficient the gate would have been fine but because of the angle you needed a larger gate... Something along those lines. Not to mention the small downpipe size.
Old Mar 6, 2013 | 04:35 AM
  #183
fly350z's Avatar
fly350z
what do you guys know about the GTM Twin Turbo Kit? i can get one used for $4500 shipped from Majestic Motorsports in NC. There is no shaft play in the turbos or any damage to any part of this kit
This kit comes with the following parts:
Cast Ductile Iron Exhaust Manifolds And Turbine Housing
Pre-Bent Stainless Steel Heat Shields
Exhaust Manifold Install Hardware Kit
4-Ply High Resistance Nomex Silicon couplers
Stainless Steel T-Bolt clamps
3.5 x 13 x 24 Bar and Plate Core Intercooler Rated 1000hp
GTM Steering Coupler
Polished Stainless Steel and Tig Welded Piping
Pre-made steel braided oil and coolant Supply & Return lines
Garrett's Twin ball bearing water & oil cooled turbocharger
Cold Air Intake System (using k&n filters)
TiAL 50mm Blow-off Valve
HKS Internal Wastegate Actuators
Attached Thumbnails SEXY Girl doing 500-600whp turbo build!!!-img_3068.jpg   SEXY Girl doing 500-600whp turbo build!!!-img_3077.jpg   SEXY Girl doing 500-600whp turbo build!!!-img_3076.jpg   SEXY Girl doing 500-600whp turbo build!!!-img_3070.jpg   SEXY Girl doing 500-600whp turbo build!!!-img_3075.jpg
Old Mar 6, 2013 | 05:04 AM
  #184
Nismo350z#0310's Avatar
Nismo350z#0310
GTM kits are good, the biggest downside is fitment. If it's just your wife/girlfreind/freind/whatever, it's going to be quite an experience trying to get that thing on. And with no instructions, forget about it. Also, I'm friends with Leabear. No confirmation of a relationship there as well.
Old Mar 6, 2013 | 05:31 AM
  #185
fly350z's Avatar
fly350z
thats funny because it says in a relationship with me right there on her page in her info
Old Mar 6, 2013 | 05:51 AM
  #186
Alberto's Avatar
Alberto
Cranky FI Owner
Post the episode/link of "Please Fawk my Wife" where you are sitting in the corner for confirmation.
Old Mar 6, 2013 | 06:24 AM
  #187
str8dum1's Avatar
str8dum1
contrary to your opinion, thats not the gate, thats the old pipe routing fault. swapping out the gate to any other 38mm as was suggested wont make any difference.
majestic is localish and does great work and i'd have no problem buying a used kit from them.
OT: alberto, whens the last time you drove your Z, just curious. Havent seen any vids in a quite a while. no one really posts driving vids anymore.
Old Mar 6, 2013 | 07:47 AM
  #188
ace32x's Avatar
ace32x
probably has privacy set to custom and has it only showing to you
b!tches be crazy
Old Mar 6, 2013 | 07:48 AM
  #189
ace32x's Avatar
ace32x
everything on my kit fit very well except the bracket on the intecooler didnt match the old crash bar mounting spots very well. and it seems to be a common thing for theyre cast manifolds to crack. one of mine cracked and i think i remember seeing that midz350 went through a set or 2 of them aswell.
Old Mar 6, 2013 | 08:07 AM
  #190
redline06's Avatar
redline06
b!tches be crazy
Says "In a Relationship with Jason ......." on mine
but yes b!tches be crazy lol
Old Mar 6, 2013 | 08:15 AM
  #191
Pholicious's Avatar
Pholicious
+1 the part about no one posting driving vids anyway.
Old Mar 6, 2013 | 09:04 AM
  #192
Nismo350z#0310
They may have improved some of the fitment issues, there were repetitive complaints on this in the past. Some of this could be installer error, but I've been advised that removing the engine makes it a lot easier. Hope my experience is the same as yours for fitment.
Edit: The "in a relationship" was just added on her page. Either someone's reading this or someone got an ear full.
Old Mar 6, 2013 | 09:09 AM
  #193
Resmarted's Avatar
Resmarted
I'm pretty sure he meant swapping out the gate for a bigger one, which would in fact help with boost control on lower levels.
But you yourself said and agreed to what I stated in that these things are fine for stock block hp levels at best:
+1
To increase the reliability, dont push the kit past what it was intended for. Everyone bitches about it bc they want too much. The kit wasnt designed for more than stock block use. But tuned in that range, its perfectly fine.
Larry at SP is a great guy. They dont have Uprev though, so you'd have to have the cable and rom editior yourself and bring it to him.
Also a member who owns the kit has an upgraded DP and bigger wastegate for 430ish hp.
We really don't need to drag out the problems with the turbonetics kit. It's been documented a million times on here with plenty of opinions. It's a waste of time to get on a built setup simply because you're going to have to replace so much sh** for the same price you could get a used greddy and have a far far more capable setup.
https://my350z.com/forum/forced-indu...-reliable.html
Old Mar 6, 2013 | 09:10 AM
  #194
ace32x's Avatar
ace32x
yea we pulled the engine, i wouldnt say its impossible. but theres no way i would ever want to try it in the car especially if your running theyre open dump set up.
Old Mar 6, 2013 | 10:47 AM
  #195
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
This thread is hilarious on so many levels.
+1 to what Resmarted said. Vinny Ten posted this vid on FB yesterday.
<iframe width="560" height="315" src="http://www.youtube.com/embed/GhbMd37FOy8?rel=0" frameborder="0" allowfullscreen></iframe>
Old Mar 6, 2013 | 10:54 AM
  #196
str8dum1's Avatar
str8dum1
do you see all that smoke coming out that car? its smokes so bad you cant even see teh cars in the parking lot anymore.
Old Mar 6, 2013 | 04:33 PM
  #197
buzzardmountain's Avatar
buzzardmountain
I have an APS TT tuner kit. Also have the big 3.5" test pipes to add to it. Never installed. Haven't listed it in the classifieds yet.
http://www.airpowersystems.com/350z/350z_tt_tuner.htm
Old Mar 7, 2013 | 04:36 AM
  #198
Nismo350z#0310
So what new kit you going with OP. I see your lady friend putting her TN kit up for sale on my news feed.
Old Mar 7, 2013 | 07:02 AM
  #199
graffkid732's Avatar
graffkid732
Rofl!
Old Mar 7, 2013 | 08:12 AM
  #200
jerryd87's Avatar
jerryd87
op just send her my way ill help her out no problem and dont even need to worry about me because im married myself
