vortech/stock block let go...so *knock on wood, reliable build thread ;-)
Old May 29, 2013 | 05:07 PM
  #141
Colombo's Avatar
Originally Posted by J rad
I respect someone that does their own work, nothing feels better than knowing what has been done to your car, and knowing it was done correct. I'll be keeping an eye out for when she is ready for start up! Congrats man.
thanks man
Old May 30, 2013 | 10:53 AM
  #142
Ruthless18x's Avatar
Ruthless18x
Looking good bro.
Old May 30, 2013 | 11:43 AM
  #143
meanz's Avatar
meanz
Looking good man! I have 2 extra blocks I want to try and build one day.
Old May 30, 2013 | 04:32 PM
  #144
Colombo's Avatar
Looking good bro.
thanks gents!
do it! i wish i had 1 spare long ago!
almost there!!!! valve covers just sitting on top. SSV is getting cleaned as we speak. few more things left and shes ready to go back in and reconnect everything.
Old May 30, 2013 | 07:50 PM
  #145
CTZ860's Avatar
CTZ860
Hey man on a side note how long did ur car go for? How many miles setup like this?? Sorry if u mentioned on another page but I'm on my phone and only read pg 1.
Old May 31, 2013 | 03:10 AM
  #146
Colombo's Avatar
on the stock block i got around 9 months out of them. thats just a guess tho. twice a month or atleast monthly track time and always driven hard. the motor still ran and felt great when i took it apart. just smoked under boost and i was getting alot of oil blow by. thats why i checked compression and got 90 on 2 cylinders . btw i have no idea how many miles. in a 9 month time span atleast 2-5k (maybe)
Old Jun 3, 2013 | 08:30 AM
  #147
Colombo's Avatar
Motor is in the car and were starting to get everything reconnected. More pictures soon!!
Old Jun 3, 2013 | 11:40 AM
  #148
Colombo's Avatar
motor is in and things going smoothly.
fluidampr
question. does this require a larger belt?
Old Jun 3, 2013 | 11:42 AM
  #149
Colombo's Avatar
btw most important updates have been edited into the first post aswell.
Old Jun 3, 2013 | 01:07 PM
  #150
the3kgt2's Avatar
the3kgt2
The fluidampr is stock size so it doesn't need a larger belt. Only ATI pulley is larger and needs a larger belter.
Old Jun 3, 2013 | 07:07 PM
  #151
350z006's Avatar
350z006
Actually, the fluidampr is slightly bigger than the stock size...
fludiampr - 6.125" OD
stock - 5.75" OD
And for everyone's info, ATI - 6.61" OD
That being said, it may be possible to use the same belt as stock size...I have a revup kit so I wouldn't know for sure...
Old Jun 4, 2013 | 03:18 AM
  #152
Colombo's Avatar
Post
stock - 5.75" OD
Thanks for the clarification I put the stock butt to butt n they def weren't the same. I'll try w my belt see if it works. Should be fine I'm thinking just tighter :-) today prob try and get that pulley on as it seems like a tight fit, mount blower back on bracket and install and a few more touches. Got the wiring harness on place and connected 90%. Getting close
Old Jun 4, 2013 | 10:16 AM
  #153
350z006's Avatar
350z006
And with a Vortech, tighter is better......
That's what she said
Old Jun 5, 2013 | 09:53 AM
  #154
Colombo's Avatar
Old Jun 5, 2013 | 10:09 AM
  #155
JaE35z's Avatar
JaE35z
Great build, can't believe i missed this! Best of luck putting it all back together
Old Jun 6, 2013 | 05:58 AM
  #156
Colombo's Avatar
Thanks man, I'm only working on it 2-3 hours a day after work tryin to make sure I cover all the bases. The new intake manifold forced me to move the fpr so I needed a longer fuel line so that set me back a day but so far things are going pretty smooth. The fluidampr seems really tight to install which I'm assuming is why they sell a 140 dollar install tool but in trying to make my own install tool out of a all thread 16x1.5mm so hopefully that will help w the install, blower should go on today as well as some piping.
Old Jun 7, 2013 | 06:56 PM
  #157
Colombo's Avatar
test fitting piping to make things fit better then they did with the old motor.
Old Jun 8, 2013 | 02:33 PM
  #158
Colombo's Avatar
Question for the big hp Vortech guys, what are you running as far as a catch can setup or to help w crankcase ventilation? Drilled out PVC? N driver side valve cover w filters on both? Or what? So much miss information on this
Old Jun 8, 2013 | 09:51 PM
  #159
OldManZ350's Avatar
OldManZ350
Check your email.
Old Jun 9, 2013 | 06:32 PM
  #160
Colombo's Avatar
Ready for first start up Tom after work :-)
