Injector inpendance
Old Mar 4, 2013 | 12:58 PM
Da_tigga's Avatar
Da_tigga
Question Injector inpendance
Hey guys I've been wanting to go turbo for some time, and now i finally got the cash to do it. My question is this, is 550cc injectors enough for around 7PSI. i talked to the guys at uprev and i was told that inpendance on those injectors would be too high and unsafe, that I needed 720s at least. should i get 720s or is it overkill?
Old Mar 4, 2013 | 01:54 PM
rcdash's Avatar
rcdash
Impedence has nothing to do with the size of the injector (these days anyway). As long as you can idle well, there is no reason to go with a smaller injector. They all cost the same (until you jump to 2000cc!). If you are using the stock ECU for tuning (UpRev), get a high impedence injector (I recommend Injector Dynamics).
Old Mar 4, 2013 | 05:06 PM
iideadeyeii's Avatar
iideadeyeii
I'm using these for my build.
http://www.ebay.com/itm/Nissan-2003-...7c459b&vxp=mtr
Old Mar 4, 2013 | 07:59 PM
Da_tigga's Avatar
Da_tigga
rcdash thats exactly what uprev recommended and i am using osiris for tunning. The guy just told me that the duty cycles would be above 100% or something like that. The kit im getting comes with 550 injectors and they guy i talked to made a big deal about them.
iideadeyeii those are cheap!!!!! are you going turbo as well?
Old Mar 4, 2013 | 08:27 PM
Triji's Avatar
Triji
Im going with Injector Dynamic 725's and ID 1000 plug and play connectors on a Vortech set up. I would HIGHLY recommend listening to uprev and their suggestion since you will be using their software and they know what they are talking about.
Old Mar 7, 2013 | 09:22 AM
Da_tigga's Avatar
Da_tigga
Thanks for the info guys
Old Mar 7, 2013 | 02:31 PM
rcdash's Avatar
rcdash
Why? Same price, might as well get 1000cc. Should still idle like stock, right (not sure with UpRev, but curious)?
Old Mar 7, 2013 | 02:51 PM
Triji's Avatar
Triji
Im going w/ Haltech now and the 725's are what Hal recommended actually... They will have plenty of flow for a Vortech setup kept to under 500whp.
Old Mar 7, 2013 | 03:10 PM
Da_tigga's Avatar
Da_tigga
Triji what numbers are you shooting for? I just pulled the trigger on BP's kit and hoping for 400 at the wheels.
Old Mar 7, 2013 | 03:25 PM
Triji's Avatar
Triji
I should be sitting around the low to mid 400's I am guessing on a Vortech SC set up. I am not going to fall for the 'my350z' trap and go for big forum numbers just to boast... I want real world drivability and fun on a reliable build.
Old Mar 7, 2013 | 03:37 PM
Da_tigga's Avatar
Da_tigga
Cool cool good luck with it man.
Old Mar 7, 2013 | 04:29 PM
iideadeyeii
Yes almost done
Old Mar 8, 2013 | 02:56 PM
Da_tigga's Avatar
Da_tigga
what kit are u using?
