Finally in the FI game
Old Jul 16, 2013 | 12:34 PM
  #61
J rad's Avatar
J rad
Get it running! Hopefully I'll see you around
Old Aug 21, 2013 | 08:49 PM
  #62
Da_tigga's Avatar
Da_tigga
Update
I got the car running again, I found that there was an exhaust leak before the turbo which may have caused late spool on my last dyno. I also added a new exhaust to the mix.
Car is much more responsive and on the logs i did I see AFRs in the low 13 high 12s at around 60% load and 11.25 even at 80%. Also which log is the one for timing on cipher? I feel like it needs a retune do you guys think i could just get away with setting my boost controler to a certain boost in the mean time? Im scared of boost spikes. (BC not in car yet) I ordered the AEM tru boost but its taking a while to get here, also good tunners are far from me.
Old Aug 22, 2013 | 06:21 AM
  #63
ksuberk54's Avatar
ksuberk54
How much boost were you running when you got 375?
Old Aug 22, 2013 | 02:24 PM
  #64
Da_tigga's Avatar
Da_tigga
around 7 pound they all were at the boost level more or less
Old Aug 22, 2013 | 03:02 PM
  #65
ksuberk54's Avatar
ksuberk54
Get some headers, slap on that exhaust and re-tune! You should be around 400 with that setup. Are you running a plenum spacer as well?
Old Aug 22, 2013 | 09:30 PM
  #66
Da_tigga's Avatar
Da_tigga
Exhaust is on and it runs great AFR is on target. im just worried about boos spikes
Old Aug 30, 2013 | 02:35 PM
  #67
Da_tigga's Avatar
Da_tigga
Got the car retuned for anyone who is still cares.
Note this is a 4th gear pull and 6 lbs at about 97* and 35% humidity
Old Aug 31, 2013 | 07:22 AM
  #68
ksuberk54's Avatar
ksuberk54
Not bad at all. Up that boost to 7.5 and you're at 400-415. Nice work.
3vilbunny
Jul 18, 2017 05:10 PM
Jambo016
Sep 16, 2016 01:08 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
