Changing Vortech V3 Air Filter on 350Z
Old Feb 11, 2014 | 07:09 AM
mazymus's Avatar
mazymus
Default Changing Vortech V3 Air Filter on 350Z
I'm pretty much assuming that we have to take the blower off to do this, right?
Sounds like a pain to do.
BTW, how often do you guys replace/clean the filter
Thanks
Old Feb 11, 2014 | 07:20 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
is the V3 any different than the v2 as far as mounting or filter?
Try going through the wheel well.
Old Feb 11, 2014 | 08:49 AM
str8dum1's Avatar
str8dum1
ya thru wheel well is easiest
Old Feb 11, 2014 | 01:45 PM
mazymus's Avatar
mazymus
I see. As in remove the front left wheel and then go from there?
PS, what is the hose that's connected to the filter?
Thanks guys!
Old Feb 11, 2014 | 02:03 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
hose goes to the back of the drivers side valve cover. May sure you reconnect it when you reinstall.
Old Feb 11, 2014 | 02:14 PM
mazymus's Avatar
mazymus
is there a DIY guide out there for going through the wheel well? didn't find anything on my search, although it wasn't a deep search. i'll do it again.
ty
Old Feb 11, 2014 | 02:45 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
lossen lug nuts
jack car up
remove lugs
remove wheel
with a 10mm socket, remove the bolts from the lower heat shield that tie into the front fender liner ( i think 3)
with a flat head, pop the 3 plastic clips holding the fender liner in
remove fender liner
remove filter
install in reverse
Its a really simple process.
Old Feb 11, 2014 | 05:03 PM
mazymus's Avatar
mazymus
Thumbs up
Originally Posted by Cux350z
lossen lug nuts
jack car up
remove lugs
remove wheel
remove fender liner
remove filter
install in reverse
THank you!! I'll give it a go
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
350Z_Al
Oct 29, 2020 07:44 PM
