The abominable VQ
Old May 28, 2014 | 09:51 AM
djamps's Avatar
djamps
Default The abominable VQ
Thought I'd share....132k miles on the OEM block, boosted 6 years and 70k on a used greddy kit. Finally threw it on a dyno after a rough street retune on the old UTEC. Still laying it down after all these years - net 443whp at 8.5psi on a DD set to comparison mode (dynojet numbers FWIW).
RPM scale is a little off since we had no RPM pickup and converted from roller speed, not sure if or how much it affected the final numbers but it feels about right -- it walks all over my 420whp G35.
Last car in this vid (white):
Old May 28, 2014 | 10:45 AM
SQuaLZ's Avatar
SQuaLZ
Very impressive with the numbers and how long it has lasted!
Old May 28, 2014 | 12:07 PM
phunk2's Avatar
phunk2
good work!
Old May 28, 2014 | 05:48 PM
Dieselinvasian's Avatar
Dieselinvasian
This is awesome man. I just dropped off my car at rt tuning for a greddy tt install on stock block with a utec tune. I'm excited to see what numbers they get. My car currently has 123k but still runs very strong. Do you have any oil consumption issues ?
Old May 28, 2014 | 06:00 PM
djamps's Avatar
djamps
It consumed oil starting when the kit was installed (it was a used kit) and gradually got worse over time. As of now it's around a qt per 500mi. I'm 99% sure it's the turbo seals blowing oil into the exhaust -- compression is good, empty catch can, dry lower plenum, and plugs look normal.
Old May 29, 2014 | 06:47 PM
Dieselinvasian
I also have some oil consumption issues pre turbo. I just replaced my pcv valve before getting the stuff installed but I doubt that's it. What's your plan lol ? Just keep riding on it like that ? I think I'll be fine either way. I remember getting my used turbo kit and there was very minimal shaft play. Did you remember yours ?
Old May 30, 2014 | 04:43 AM
rcdash's Avatar
rcdash
Good news is it is cheap to rebuild journal bearing turbos. Bad news is you have to pull them off and they are in a tight spot.
Old May 30, 2014 | 09:14 AM
djamps's Avatar
djamps
No idea on shaft play, when I pulled the downpipes off I saw there's another pipe after the turbo the wastegate dumps into, so I couldn't get to the shaft easily. I'm assuming there's excessive play tho...
Plan is to ride dirty for a while longer, then rebuild turbos and engine at the same time... along with a DW400, bigger lines and rails, ID1000 injectors, and uprev instead of UTEC.
Old May 30, 2014 | 10:07 AM
Classy's Avatar
Classy
Are you going to refresh the engine or actually build it?
Old May 30, 2014 | 07:38 PM
djamps's Avatar
djamps
fully build
Old May 30, 2014 | 08:06 PM
Dieselinvasian
What ! I just decided on keeping the utec I had on this build. Lol it was a toss up between that and uprev. Don't make me change my mind again! Lol
They didn't start my car yet and I still have a chance to change my mind! I don't know anymore
Old May 30, 2014 | 08:47 PM
ronn1's Avatar
ronn1
WOW!
Old Jun 13, 2014 | 01:36 PM
djamps's Avatar
djamps
UTEC will have spark blowout over 550whp or so without ignition system hacks (voltage boosters ect)...something to do with an incorrect dwell. since my goal is 600+ kind of ruled out UTEC.
Old Jun 16, 2014 | 12:18 AM
Drako_MDx's Avatar
Drako_MDx
If your goal is 600whp... I would skip Uprev and go straight to Haltech.
Old Jun 16, 2014 | 04:39 AM
djamps's Avatar
djamps
As of now I have a spare uprev license and hpx maf so figured I'd put it to use. If a good deal comes up on a used haltech I'd def. consider it.
Old Jun 16, 2014 | 09:27 AM
Drako_MDx's Avatar
Drako_MDx
Don't get me wrong... the Uprev will work out just fine but you'll have to spend a little extra money to protect the engine since Uprev is limited on that department.
By the way... Has anyone noticed that the Uprev site seems corrupted. Eveything I have on my PC for protection prohibits me from even going to there site.
Old Jun 16, 2014 | 05:56 PM
Escobar's Avatar
Escobar
I havent had any problems with the website. Great numbers and durability DJ. I wish we all could have that reliability. Im hoping mine fairs well.
Old Jun 16, 2014 | 06:14 PM
taywan's Avatar
taywan
Oh man, I'd be very nervous about boosting at that mileage and hope the best for it.
Aweswome power at 8.5 psi. I'm so jealous, I wish I had that power !! I need to build my spare block !!
treefiddyzeeh
Apr 5, 2012 05:27 PM
Abomination
Nov 2, 2004 11:21 AM
