Procharged G35
Old May 10, 2016 | 07:17 AM
  #381
Conway_160's Avatar
Conway_160
Originally Posted by BluestreamDE
That really sucks! This was your 3rd time putting it back together? Im real sorry you are going thru this.
Something like that :-(
Old May 10, 2016 | 01:58 PM
  #382
Resmarted's Avatar
Resmarted
Hm. Interesting. Hard to know in those pictures for sure because of how small they are.
Old May 10, 2016 | 02:58 PM
  #383
Conway_160's Avatar
Conway_160
LOL well those are supposed to be videos, suppose ill upload to youtube..
Old May 10, 2016 | 03:04 PM
  #384
Conway_160's Avatar
Conway_160
http://vid718.photobucket.com/albums...ps7h7yz0rb.mp4
http://vid718.photobucket.com/albums...psfhxqzimf.mp4
http://vid718.photobucket.com/albums...psj8gxfmqj.mp4
Old May 10, 2016 | 04:01 PM
  #385
Resmarted's Avatar
Resmarted
I only watched the first one, but it's still hard to tell if some of the spotting is detonation in the piston or fluid of some kind. I can not personally judge it in that video, although I can see why you would suspect DET, especially toward the outer edge of the piston it did look like white spotting for just a moment.
Old May 11, 2016 | 05:29 PM
  #386
Conway_160's Avatar
Conway_160
Haltech is installed now just waiting on the cams to do a leak down to see how bad its hurt or if its hurt at all.
Old May 28, 2016 | 04:14 PM
  #387
Conway_160's Avatar
Conway_160
ITS ALIVE, but my haltech can't/wont read my stock widebands...WTF
Old May 29, 2016 | 09:22 PM
  #388
jdm-v35's Avatar
jdm-v35
because 03-04's dont have stock widebands...
Old May 30, 2016 | 09:07 AM
  #389
Conway_160's Avatar
Conway_160
Uprev read my widebands, and i know i have widebands since mine are five wires instead of four. Also mine is a late model 04.
Just verified i have to M vin and not the T.
Old Jun 4, 2016 | 05:39 PM
  #390
Conway_160's Avatar
Conway_160
Well the car is running smooth just need to order a dual channel wideband controller and wire it into the haltech so i can start tunning.
Put in a new slave cylinder after about 15 minutes of bleeding and no air coming out i still dont have a clutch...wtf!
Old Jun 8, 2016 | 12:44 PM
  #391
Staisman's Avatar
Staisman
Do you have stock pedal or RJM ??
Old Jun 8, 2016 | 01:24 PM
  #392
Conway_160's Avatar
Conway_160
Stock Pedal, im quite sure i need to do some more bleeding.
Old Jun 8, 2016 | 05:11 PM
  #393
2bad240's Avatar
2bad240
Take the top clutch sensor out so pedal can travel all the way up
Old Jun 8, 2016 | 05:57 PM
  #394
Conway_160's Avatar
Conway_160
Ok ill do that tomorow
Old Jun 9, 2016 | 02:31 PM
  #395
Conway_160's Avatar
Conway_160
Wideband is here, now time to figure out how in the world am I going to route the wires...The sensor is going to be in my Cubby above my Stereo. I'm thinking I want to run my wires threw my shifter location but idk yet. Any inputs would be greatly appreciated.
Old Jul 27, 2016 | 08:10 PM
  #396
Conway_160's Avatar
Conway_160
I cant not get this damn clutch to bleed.....fml!
Old Sep 10, 2016 | 10:39 AM
  #397
Conway_160's Avatar
Conway_160
Well I pulled the transmission yesterday to look at my Fork and Clutch. Fork was ok and I loosed the pressure plate and re-torqued it to 31ftlbs like it says to in the JWT instructions. I couldn't remove my pressure plate all the way since I couldn't find my alignment tool. Got it all put back together and the clutch still doesn't disengage. I have the master cylinder at a full stroke so i can get the most movement out of my slave cylinder. I measured it and the slave is only moving 1/2" I was told it should move roughly 5/8" so i found a 1/4" piece of medal and put it in-between the slave cylinder and the bottom of the fork to see if that extra movement would disengage the clutch...NOPE.
So next free weekend i get I'm pulling the transmission again and pulling off the pressure plate and clutch all the way to make sure something isn't F'ed since i found my damn alignment tool in the top of my tool box
Old Nov 26, 2016 | 05:42 PM
  #398
Conway_160's Avatar
Conway_160
Well car blew a head gasket....procharger is for sale to fund next step in the build....:-(
Old Nov 26, 2016 | 10:10 PM
  #399
bealljk's Avatar
bealljk
why did it pop the head gasket?
Old Nov 27, 2016 | 04:36 AM
  #400
Conway_160's Avatar
Conway_160
I think because it got hot, it had a coolant leak and was low on coolant that I didn't catch until it was to late. But the temp Guage never went out side the normal range.
