Budget Single Turbo Build! High mileage
Old Mar 26, 2015 | 11:10 AM
  #141
woody03's Avatar
woody03
Thats not bad for a budget build. Should be a fun car after all the tuning is sorted. You on 93?
Old Mar 26, 2015 | 11:14 AM
  #142
le mans sunsetz's Avatar
le mans sunsetz
Ya pretty good if it does make that. Hopefully it all holds together. And yes 93
Old Mar 26, 2015 | 06:27 PM
  #143
woody03's Avatar
woody03
I want to see how well the exhaust side holds up. I wouldnt worry too much about the other stuff.
Old Mar 26, 2015 | 08:44 PM
  #144
le mans sunsetz
Yes. Only thing about the turbo kit I'm worried about. Apart from the motor itself. I'm not a welder or know much about it. But just by looking at it, the welds look somewhat sloppy and weak. Idk if they really are but just by looking at it they appear to be. The crossover pipe especially as it has a flex joint it most likely has a lot of movement.
If they break I would assume I could get a replacement pipe from turbonetics.
Old Mar 28, 2015 | 10:29 AM
  #145
le mans sunsetz
Was hoping to have to it back today but haven't heard from them. Now hoping for Monday or Wednesday.
Old Mar 29, 2015 | 04:12 PM
  #146
le mans sunsetz
Also I have a nismo cold air intake, stock injectors, stock cats, and the stock spoiler if anyone's interested. Probably a bad place to advertise but oh well. Contact me if interested.
Old Mar 29, 2015 | 04:24 PM
  #147
le mans sunsetz
Mountains of pa
Old Mar 29, 2015 | 04:39 PM
  #148
Conway_160's Avatar
Conway_160
[QUOTE=le mans sunsetz;10570878][QUOTE]
That FMIC is small.
Old Mar 29, 2015 | 04:42 PM
  #149
le mans sunsetz
Originally Posted by Conway_160
That FMIC is small.
Im aware. I think it's the same size that comes with the turbonetics. Should work fine for what Im trying to accomplish. It does fill up the bumper space atleast! haha. They easily could have added a few inches to the height though!
Old Mar 29, 2015 | 05:00 PM
  #150
woody03's Avatar
woody03
It will work for a stock block Z. Might be leaving a few hp on the table but itll work.
Old Mar 30, 2015 | 09:39 AM
  #151
trusovici's Avatar
trusovici
Default Sick
Sick dude!
Old Mar 30, 2015 | 02:44 PM
  #152
le mans sunsetz
Getting back on the dyno tomorrow with the new maf.
Old Apr 1, 2015 | 08:03 AM
  #153
le mans sunsetz
He said he got it back on the dyno and it's still running lean because of the fuel pump. And he said the clutch is slipping? It's a brand new clutch. They're good for 400whp?
Old Apr 1, 2015 | 08:25 AM
  #154
woody03's Avatar
woody03
The walbro 255 isnt maxed out on your car. Is it an oem clutch? Did you give it the proper break-in? Id pay the shop a visit to see this stuff myself.
Old Apr 1, 2015 | 08:58 AM
  #155
iideadeyeii's Avatar
iideadeyeii
I'm using stock fuel pump on 550cc injectors at 7psi with the same kit you have(except it's a replica (godspeed) with what I believe is to be a stock clutch.
First the MAF now the fuel pump. . .sounds like he's dicking you around
Old Apr 1, 2015 | 10:13 AM
  #156
le mans sunsetz
He said he assumed I had a fuel pump in it already when he went to dyno this morning since I had injectors. So it initially probably ran lean because of the fuel pump not the maf. I told him to leave the clutch alone. If anything I'll get some use out of it and switch it myself if it goes
Old Apr 1, 2015 | 10:15 AM
  #157
le mans sunsetz
Even with the stock fuel pump he said he was still only at 300. It should handle more than that
Old Apr 1, 2015 | 10:29 AM
  #158
woody03's Avatar
woody03
I agree that he is probably lying. I havent seen an uprev interface but im assuming it gives you a way to read maf voltage. Thats what should be used to determine the maf was maxed. It isnt a guessing game. Id take the car somewhere else.
Old Apr 1, 2015 | 11:43 AM
  #159
le mans sunsetz
Even if I do at this point I'm already owing them for the labor parts and the tune and then would have to pay another place to finish the tune. Which means buying the whole uprev platform and the tuning. So that would be like another $1200 at least I would think
Old Apr 1, 2015 | 11:44 AM
  #160
le mans sunsetz
I would understand if the stock parts started leaning out closer to 400 but he said it's still at 300
