Budget Single Turbo Build! High mileage
Old Mar 22, 2015 | 11:21 AM
  #121
le mans sunsetz's Avatar
le mans sunsetz
Tpg *
Old Mar 23, 2015 | 05:24 AM
  #122
trusovici's Avatar
trusovici
what do they charger per hour?
Old Mar 23, 2015 | 07:58 AM
  #123
le mans sunsetz
Just got a call from them. They said there was a few minor things they needed to tweak which I was expecting. They charge $100 an hour for labor 400 for the tune and 200 for the uprev license.
Old Mar 23, 2015 | 08:46 AM
  #124
le mans sunsetz
The guy who would be doing the tuning was the guy I talked to and sounded very reassuring that all would be good. He didn't even mention the high mileage or godspeed piping parts. He just said he would have it base mapped and running as soon as the fix the minor things. Apparently I put the wastegate on backwards? LOL. Btw I'm only 18 and this is my first big build on a car so I was expecting to miss some things. It's a learning experience for me
Old Mar 23, 2015 | 03:51 PM
  #125
bmccann101's Avatar
bmccann101
nice job ^
Old Mar 24, 2015 | 11:56 AM
  #126
le mans sunsetz
Tuner just called and said he had it on the dyno and everything was right where it should be for a stock motor. He had it at low boost which was 6 pounds and he said it quit making power at 5500rpm so he had to order an uprev maf. Was not expecting that. Another $400 added on. Very excited though. Looks like he thinks it can handle more power than I thought.
Old Mar 24, 2015 | 12:17 PM
  #127
iideadeyeii's Avatar
iideadeyeii
I thought stock maf was good to about 400whp? No way you're over that with 6psi
Old Mar 24, 2015 | 02:08 PM
  #128
le mans sunsetz
He originally told me before I brought it in that I would need one if I'm doing over 8 or 9 psi. So I was confused when he said I needed one too
Old Mar 24, 2015 | 02:12 PM
  #129
le mans sunsetz
So ya my $600 tuning trip turned into around $2000 really quick when you count in towing, gas, tolls and labor haha
Old Mar 24, 2015 | 02:15 PM
  #130
le mans sunsetz
So unless you know how to tune a FI 350z there's no such thing as a budget build
Old Mar 24, 2015 | 02:54 PM
  #131
woody03's Avatar
woody03
I'm wondering why you need a new MAF. What size piping are you using? How much power did you make?
Old Mar 24, 2015 | 03:42 PM
  #132
le mans sunsetz
That's what I'm wondering. 2.5 inch piping and then 3 inch to the throttle body. I couldn't imagine it made more than 350whp
Old Mar 24, 2015 | 04:13 PM
  #133
le mans sunsetz
Perhaps he's trying to push the sale on me because they're a distributor of uprev? I have no problem spending the money, but if it's unneeded I'll be pissed
Old Mar 24, 2015 | 04:59 PM
  #134
woody03's Avatar
woody03
I'm sure I missed this but are you using the stock exhaust system? Also, 400 bucks for a MAF is expensive. The HP MAF is 250 last i checked.
Old Mar 24, 2015 | 05:05 PM
  #135
le mans sunsetz
I have a nismo cat back. No catylitic. I guess the stock Maf is good for anywhere from 350-400whp. I'm just surprised it's making that much power on low boost.
Old Mar 24, 2015 | 05:27 PM
  #136
woody03's Avatar
woody03
At what point does the piping step up to 3 inches? Id be surpised to see that much power honestly.
Old Mar 24, 2015 | 06:14 PM
  #137
le mans sunsetz
Like 3.5ft from the tb. It's 2.5 out of the turbo to intercooler.About halfway out of the cold side it transitions from 2.5 to 3 inch.
Old Mar 25, 2015 | 07:12 AM
  #138
Conway_160's Avatar
Conway_160
I maxed out my MAF at 361whp at 10psi on my Procharger.
Old Mar 25, 2015 | 03:12 PM
  #139
le mans sunsetz
I will post some of the pictures of the car finished tonight or tomorrow. I also have a video of the first start with the bigger r35 injectors. Pretty much it runs enough to drive on a trailer. No more than that lol. Should have the car back fully dynoed Saturday. Not sure if I mentioned that already. I'll will post pics and videos. I will also give a review type thing that day as I have to drive it back 150 miles. So I should get a good feel for the new power.
Old Mar 26, 2015 | 10:55 AM
  #140
le mans sunsetz
Got to talk to the tuner on Facebook. It made just at 300whp at 5krpm before he let off do to pegging the maf and going lean. He thinks it will be in the 350 range on a mustang dyno which reads 10% low (correct me if I'm wrong) so 385ish. With new maf**
