Engine Build
Old Jan 19, 2016 | 03:35 PM
  #41
woody03's Avatar
woody03
Just bumping my old thread. I eventually got the bushings replaced. I went with the SPL differential kit. This was a huge PITA until I gave up and took the subframe out from under the car. After that, it was fairly easy.
I'm getting ready to order some more parts shortly. I plan on getting new wheels/tires, setting up a quick spool valve, and possibly getting a vacuum block done. I'm also grabbing the revup oil pump and Fluidampr. This build is still a work in progress, but I will eventually get it completed.
Old Jan 20, 2016 | 07:20 AM
  #42
ogiehooker's Avatar
ogiehooker
Default GTX
Upgrade to a GTX turbo billet wheel for more power everywhere....
Whats cooling YOUR engine...
Attached Thumbnails Engine Build-powdercoated-core-support-installed-oil-coolers-only.jpg
Old Jan 20, 2016 | 08:04 AM
  #43
woody03's Avatar
woody03
As of right now its completely stock. IDK if any upgrade is required for what Im wanting. I know it wouldnt hurt, but I dont see it being necessary either.
Old Feb 18, 2016 | 11:18 AM
  #44
woody03's Avatar
woody03
I found a leak on the oil feed line for the turbo. Does anyone know what size fittings are used in the powerlab kit?
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
