2bad240's journey to the world of vortech
Old Jun 11, 2015 | 05:49 PM
  #41
OldManZ350's Avatar
OldManZ350
11:1 cr
Originally Posted by meanz
bad a$$ way to put together your own piping! Looks sick and making great boost on a 3.33 pulley!! I need to go to bigger ati crank pulley next.
Old Jun 12, 2015 | 08:03 PM
  #42
Resmarted's Avatar
Resmarted
I'm trying to put my bracket on. Looks like I either didn't get or didn't realize I needed to buy the m12X110mm bolts. Did yours come with those bolts?
Old Jun 12, 2015 | 08:43 PM
  #43
2bad240's Avatar
2bad240
No mine didn't come with anything. I got a couple Allen head bolts from fastenal. I got a few spare if you want them just pay shipping.
Old Jun 12, 2015 | 10:34 PM
  #44
Resmarted's Avatar
Resmarted
Wow thanks for the offer man! Fortunately I de-retarded myself while working on the car and figured it out. I had the 110mm on the cog tensioner location. I kept looking at it like WTF why would vortech give a bolt that's too long to fit in the groove of the S/C and slide all the way down?
Then I realized it was the correct pitch to fit in the stock location... So I put the stocker in the cog hole and that one in the plate/cover. I also scrounged a 120mm bolt and grazed it down with a angle grinder bit by bit to 110mm and put that with the spacer in the other m12 hole so I think I'm set... I felt like an idiot realizing that after so long. Oh well, at least I didn't have to order more crap... Yet... lol.
Thanks again for the offer I appreciate it.
Old Jul 1, 2015 | 01:45 PM
  #45
2bad240's Avatar
2bad240
Been a few weeks since I updated. Anyway had a coolant hose bust and leak about two weeks ago on the day it was 100* the car overheated and the oil thinned out and oil pressure dropped while I was out driving. As some may know I had flash boiling issues while cruising with my procharger setup. So I decided to take the time to weld up all excess coolant ports and do the HR mod and run hr head gaskets.
So I decided to freshen the engine up and I went with a lightened balanced crank and went ahead and replaced all the bearings while it was apart. Also decided to paint everything
So here are some pics
Old Jul 1, 2015 | 01:53 PM
  #46
studbolt03's Avatar
studbolt03
Looks Good DUDE!!!!
Old Jul 1, 2015 | 05:30 PM
  #47
Conway_160's Avatar
Conway_160
Man I wish I had your skills and patience!
Old Jul 2, 2015 | 12:01 PM
  #48
2bad240's Avatar
2bad240
Filled the trans today and made a intake for the blower and finally charged the AC all ready to drive
Old Jul 2, 2015 | 12:07 PM
  #49
2bad240's Avatar
2bad240
Video of it
http://youtu.be/jdD7-8vY04A
Old Jul 10, 2015 | 04:54 PM
  #50
2bad240's Avatar
2bad240
Don't know if it actually helps but I wrapped my intake piping with the reflective heat tape today. If anything at least I got a little color now.
Old Jul 13, 2015 | 02:16 PM
  #51
ge35es's Avatar
ge35es
where did you get the CF duct thats mounted on the bumper ?
Old Jul 13, 2015 | 03:17 PM
  #52
Resmarted's Avatar
Resmarted
Car looks and sounds great! Like that you made the titek or whatever it's called duct fully functional
Old Jul 16, 2015 | 11:38 AM
  #53
2bad240's Avatar
2bad240
eBay I do believe
Old Jul 17, 2015 | 04:34 PM
  #54
2bad240's Avatar
2bad240
Tried to make a couple pulls on the dyno today.
First run (blue) it spun
Next two runs it was choking out and only making 14-15psi and you could hear it starving out up top. Figured out after I got home it was collapsing the blower intake coupler again. So I pulled it off and took it for a street pull and boost went up to 19 and Idc went from 85% to 98%
So I was definitely losing power from the intake acting like a restrictor plate.
Old Jul 21, 2015 | 08:19 AM
  #55
2bad240's Avatar
2bad240
I think I picked the hottest day of the year to work inside the car. Spent the last 2 hours running lines and wires for nitrous.
Jets should be here tomorrow. Gonna be direct port a little less than 10hp per cylinder
Old Jul 21, 2015 | 06:34 PM
  #56
Resmarted's Avatar
Resmarted
Any reason why you went direct port over maybe like a single pre impeller? Not knocking the decision, just curious for my own setup
Old Jul 22, 2015 | 04:54 AM
  #57
2bad240's Avatar
2bad240
Already had the direct port from when I was nitrous only. And il have precise control over nitrous distribution to each cylinder. I have lots of nitrous parts so I could later add a second nozzle pre impeller for cooling if needed but my setup stays pretty cool with the bigger intercooler and piping. The highest IATs I have seen is 101 at 19psi and it was 92* outside.
Old Jul 22, 2015 | 09:19 AM
  #58
Resmarted's Avatar
Resmarted
Yeah I feel you. I want to put a pre impeller nozzel if I ever get the car working, so when I'm overspinning it, it will just make the housing more efficient. Direct port by no means is a bad idea. It's obviously safer.
Old Jul 22, 2015 | 02:09 PM
  #59
Conway_160's Avatar
Conway_160
Does not look like fun, i'll bet its a pain in the as getting all that hose to fit and still look good.
Old Jul 22, 2015 | 05:03 PM
  #60
2bad240's Avatar
2bad240
Basically just shove it down. Once it's on you can't really see any of it.
It may be 97* outside but this little project snowballed. Was gonna just put the dp manifold on and have a hand switch. But now I have added a heater and purge and master cutoff for the nitrous system and installed wot as a second switch because il also be using a window switch to control when it starts and stops spraying
