2003 wideband o2 sensor
Old Oct 11, 2015 | 12:05 AM
Smoove's Avatar
Smoove
Default 2003 wideband o2 sensor
I have searched this forum and I'm finding answers that are close but not exactly the answer to my question
I have a 2003, the 2003 came with narrow o2 sensors. Supposedly the 2004.5 and up came with wideband sensors so not a boost/tuning issue for them. I am about to boost. Do I need to replace both my upper o2 sensors with wideband?
I am going to have the uprev tune done. The Innovate Motorsports Digital MTX-L has been recommended, do I only need to replace the driver side or both sides?
I am still running the stock exhaust
Old Oct 11, 2015 | 05:13 PM
hulkout's Avatar
hulkout
You don't want to replace the factory narrow bands because that's what your ecu uses to adjust fueling. It wouldn't understand a wideband's readings. You need to get an O2 sensor bung and install a wideband in addition to the factory sensors. Either weld in (cheaper) or a clamp in one (easy if you don't weld).
These work nicely:
http://www.aemelectronics.com/?q=pro...-sensor-mounts
Old Oct 11, 2015 | 06:11 PM
Smoove's Avatar
Smoove
Thanks for the info. And no I don't weld, so the link helps a lot
Mike Wait
Tuning
May 3, 2015 02:40 PM
krazE
Apr 15, 2006 12:59 PM
juliosuburban
Jan 19, 2006 04:38 PM
fatZo
East Canada
Jul 2, 2004 05:11 AM
alkamist
Jul 30, 2003 11:27 AM
