350z VQ35DE Forced Induction Query
Old Mar 10, 2016 | 10:21 AM
  #61
Nismo350z#0310's Avatar
Nismo350z#0310
Originally Posted by gotama
272's good idle and 8300 redline sounds awesome. What cams were the 272's Tomei ? With these cams would 8300rpm be achievable on my VQ35DE '06 rev-up with this package: http://www.importpartspro.com/st1blon.html and my current stock heads ?
Cheers
i'm not sure, you should contact a shop/builder/or tuner.
I am less aware of the DE platform, havent look into it or experienced it as much.
Old Mar 11, 2016 | 08:12 PM
  #62
Resmarted's Avatar
Resmarted
Originally Posted by Nismo350z#0310
One of the most knowledgeable guys I know. Been around a good bit, managed 2 well-known VQ/VR shops, built/tuned the Zs for years, he's now a GTR tuner doing +1000whp build every day around the world.
He's tuned the highest stock motor VHR, highest stock motor HR (me), some of the best porsches and GTRs in the world.
I can understand what he's saying in that the double cam operates much different than the one cam of something like an LS. So that it's tunable to have no ill-effects at idle/low rpms. I trust what he's said, he called almost everything to the T of what would happen on my first build.
It's just contrary to what Hal and I talked about. But then again, we were talking about kelfords which run more lift than tomei by a bit and more duration by 8 degrees.
The consensus was bc 3's were as much as you would want on a street car for drive ability
Old Mar 12, 2016 | 06:38 AM
  #63
rcdash's Avatar
rcdash
^ Agree, Hal talked me out of anything higher than a 272 (he recommended and I chose Kelford but I think JWT C8 is fairly equivalent). Much wider torque band. I wanted a 3500-7500 band and he delivered. The stress on the motor above 7500 does not warrant the slight gain in performance imo.
Old Mar 13, 2016 | 03:47 AM
  #64
gotama's Avatar
gotama
MY DE is the rev-up. What about the 272 C8 rev-up version CAM's. With these cam's how much maximum rpm can a VQ35de rev-up built engine can handle safely?
cheers
Old Mar 13, 2016 | 06:24 PM
  #65
Resmarted's Avatar
Resmarted
Yeah they fit the v6 better than anything else when you're talking big power street car imho. The rod stroke ratio and displacement and everything means that 4000-7500 range is your money shot
Those new 5.0's though. Lift for days
Old Mar 15, 2016 | 04:10 AM
  #66
gotama's Avatar
gotama
to which cam's are you referring the JWT C8's or the Kelfords ?
Old Mar 17, 2016 | 03:03 PM
  #67
rcdash's Avatar
rcdash
^ the C8s and the Kelford 272s (version I have) appear to have nearly identical specifications; I believe 11 mm lift and 272 degree duration.
EDIT: Guess I was slightly off. Kelfords have 11 mm lift, BC stage 3 11.66, C8 12 mm lift. All 272 degree duration.
Old Mar 18, 2016 | 09:57 AM
  #68
str8dum1's Avatar
str8dum1
depends on your valve springs and oil pump
cheers
Old Mar 27, 2016 | 07:26 PM
  #69
Resmarted's Avatar
Resmarted
just for op:
The bc stage 3 is as much lift as you can go without having to machine the heads for clearance. 12mm lift will require clearance machine work (at least for the non rev up heads, I believe the rev ups are the same casting, could be wrong though).
It's not a big deal if you already have the motor in the shop, but if you're putting the thing together yourself (like I did), it can be another hassle. Just something to pay attention for.
Old Apr 11, 2016 | 10:51 AM
  #70
rcdash's Avatar
rcdash
^ you should read the FI sticky FAQ; many have tried to boost the VQ on the cheap, a few succeed. UpRev's Osiris is your answer btw.
Old Apr 12, 2016 | 06:10 AM
  #71
iideadeyeii's Avatar
iideadeyeii
Originally Posted by superhardware
what is cheapest way to cut speed limit?
[/FONT]
Utec
Old Apr 12, 2016 | 07:56 AM
  #72
iideadeyeii
local tunad said that no utec and amanage ultimate can not cut speed limit
Utec removes rev limiter
Old Apr 12, 2016 | 08:10 AM
  #73
rcdash's Avatar
rcdash
I don't think the UTEC can alter speed limiter, which is what he was asking about. I guess since this thread has taken a turn off road, www.uprev.com. Google is your friend superhardware
