MEANZs AAM twin turbo kit journey
Old Dec 16, 2015 | 06:11 PM
Escobar's Avatar
Escobar
nice progress. brings back memories of 1 year ago when I did mine. fun stuff!
Old Dec 18, 2015 | 05:35 AM
meanz's Avatar
meanz
I'll update this and say it's in! Fitment is very tight and precise. If it's off just a little bit, your not gonna get it in. Had install and pull engine a few times to get it lined up correctly. I'll add pics later.
Couple of small issues I had. Passenger side manifold and drivers side turbo need just a little bit more clearance. Engine gets wedged in car making it difficult to just slide back in how I'm used to. Also, we ended up pulling Tranny and mating it up out side the car. Should of did this to begin with. A lot easier.
Since there is very little wiggle room, it makes lining up the engine mount bolts to the frame difficult. I found it easier to pull out a 15 pound sledge hammer and make some room. I would imagine if you have a lift and can lower the front cross member down, do that. It will make life easier.
If you have starter removed for any reason, install it before you install manifold and turbo. You will run into a clearance issue with the oil return hitting the solenoid. Had to loosen up turbo and manifold to get started in. If you miss this step, it will cost you some time.
Intake piping on passenger side turbo is tight fit. You can have it installed when lowering engine in. Or to make it easier, just remove the power steering pump and you can access it better and install it after engine is in.
If your running a aftermarket engine mount, you might need to cut the stud down so it doesn't hit the coupler coming off of turbo. No big deal.
The passenger side turbo might rest on top of the clamps holding power steering lines, I had to remove mine to get the mount to go down into the hole.
Again this kit is a very tight fitting kit. If you don't have everything 100%. Your gonna waste time installing. There looks to be plenty of room coming out behind the turbos. Biggest issue I had was clearance on the manifolds in the bay. You might not have this issue if you drop it out the bottom, but you will have it if sliding in from the front.
Make sure to have all oil and coolant lines tightened down. You won't be able to access them in the car.
Now that the hard part is finished, I'll button everything up and post more pics. Can't wait to see how this thing is when finished. Also if you have any issues installing this kit. Customer support has been great and quickly replies back to help. Thanks Patrick..
Old Dec 18, 2015 | 05:57 AM
HRMoneyPit's Avatar
HRMoneyPit
The fact that it's so tight to important things worries me
Old Dec 18, 2015 | 06:47 AM
Highway Riding's Avatar
Highway Riding
Any kit aside from Sasha's mid mount kit will be tight... No way around it! Just have to shield sensitive lines and and make sure nothing will rub under load.
Old Dec 18, 2015 | 08:03 AM
meanz's Avatar
meanz
Here is a pic of how close the bolt and stud is on passenger side
Old Dec 18, 2015 | 08:07 AM
meanz's Avatar
meanz
Old Dec 18, 2015 | 08:10 AM
meanz's Avatar
meanz
Return line has very little room here
Old Dec 18, 2015 | 08:11 AM
meanz's Avatar
meanz
This is the bracket I had to remove for the engine mount to sit flush due to getting hung up on turbo.
Old Dec 18, 2015 | 08:14 AM
meanz's Avatar
meanz
This was before I removed clamp, that t bolt was close in this pic, wasn't touching, but I rotated it a little. Also I was able to clock turbo about 1/8 inch for more clearance.
Old Dec 18, 2015 | 11:54 AM
HRMoneyPit's Avatar
HRMoneyPit
See that's way too close to too much
Old Dec 18, 2015 | 02:13 PM
Conway_160's Avatar
Conway_160
Man this is looking good but damn that doesnt look like fun at all!
Old Dec 18, 2015 | 03:00 PM
meanz's Avatar
meanz
I actually just pulled engine again to make more room. I didn't like how close some things were. Yay
Old Dec 18, 2015 | 03:21 PM
HRMoneyPit's Avatar
HRMoneyPit
Definitely with you on that
Old Dec 18, 2015 | 04:03 PM
meanz's Avatar
meanz
And engine is back in. I have more room around manifolds and turbos. Engine dropped back In super smooth. I made some more room clocking turbos as much as possible and with the sledge also, lol. But I'm happy it's fitting better.
Old Dec 18, 2015 | 05:28 PM
rcdash's Avatar
rcdash
Turbos should be clocked 20 degrees anyway with coolant exit point higher than entry point. This facilitates coolant flow and significantly lower CHRA temps. High mounted turbos are always super tight. Any issues with the steering knuckle? Good job doing this on jack stands!
Old Dec 19, 2015 | 02:03 AM
meanz's Avatar
meanz
Thanks and no issues around steering knuckle area at all.
Old Dec 19, 2015 | 03:38 AM
taywan's Avatar
taywan
Jack stands fo life !!!!
we will have a lift in the near future...that's no doubt.
Old Dec 19, 2015 | 03:59 AM
  #38
RUNWDVL's Avatar
RUNWDVL
Guess I'm shipping my car to you guys...
Old Dec 19, 2015 | 04:01 AM
  #39
meanz's Avatar
meanz
I was just talking to Jen about this. Would of made this install little easier dropping out the bottom. Oh well, we get it done!
Old Dec 19, 2015 | 07:25 AM
  #40
taywan's Avatar
taywan
greddy twins ...
next
