MEANZs AAM twin turbo kit journey
Old Apr 17, 2016 | 05:23 AM
  #121
meanz's Avatar
meanz
Originally Posted by Conway_160
Is the torque supposed to fall like that? How much different does the power feel compared to the blower?
Car feels amazing. Easy to control. The more you stay in the gas, the more it pulls. Love how the boost by gear is working out.
I'm running my new falken rt615k tires. On the blower setup, I could punch it in 1st gear and not break loose at all. On this twin setup, it's laying down big tire marks in 3rd from a nice roll.
I'll try to get ahold of bobby sometime from Cin and use his dyno to see how it reads against the blower on same dyno. The guy I rented dyno from said not be surprised if it's putting down lower numbers than expected.
Old Apr 17, 2016 | 06:44 AM
  #122
steven350's Avatar
steven350
Sounds awesome man, congrats
Old Apr 17, 2016 | 08:18 AM
  #123
meanz's Avatar
meanz
Original post edited with mods and dyno.
Old Apr 17, 2016 | 12:21 PM
  #124
Conway_160's Avatar
Conway_160
Cant wait for the videos!
Old May 2, 2016 | 09:07 PM
  #125
meanz's Avatar
meanz
Put some miles on the z. Seems to be running good. I picked up 6 mph in the 1/8 mile. Haven't put a sticky tire on yet. But has picked up good.
Have a pic of boost graph. It ramps up then drops off a little bit. Doesn't hold steady at 18psi. Still trying to figure that out. I'm running Mac boost controller with vac lines as short as I can get. Have Mac controller mounted to side of Tranny. The vac lines drop straight down to it.
Old May 3, 2016 | 06:34 AM
  #126
OldManZ350's Avatar
OldManZ350
6 mph in the 1/8th..... way to go Josh.....that is a very huge gain.
Old May 3, 2016 | 08:50 AM
  #127
meanz's Avatar
meanz
Thanks Tim, I might be able to borrow a tire on Thursday and see what it actually does in the 1/8. Anything lower than my 7.40 spinning and I'll be happy.
Old May 4, 2016 | 05:52 PM
  #128
Resmarted's Avatar
Resmarted
Trying a bigger wastegate would be expensive but MIGHT do the trick, or relocating the external wastegates would likely solve the problem.
What do the hot side manifolds look like? If the wastegates aren't in just the right spot, they'll struggle to hold boost smoothly even if the boost controller is good.
This is assuming you have the controller installed correctly.
What's your wastegate spring pressure? If you want 18psi on the controller you'll probably want about 9-11psi on the spring. Too low of a wg spring can cause boost holding problems too.
Old May 6, 2016 | 03:39 AM
  #129
meanz's Avatar
meanz
Sent a log to Hal and he adjust the boost controller output. It's much better now. More flat and consistent. Pulls little harder now also. I need to get some vids up soon.
Old May 8, 2016 | 04:49 PM
  #130
Resmarted's Avatar
Resmarted
What EBC are you running? Did he just mess with duty cycle?
Will be interesting to see what happens when you turn up the boost.
Old May 24, 2016 | 03:58 AM
  #131
meanz's Avatar
meanz
Got to take the z to zdayz this year. Beat the crap out of the z for the entire weekend and it didn't skip a beat. Now I can focus on painting this thing now.
Old May 31, 2016 | 02:02 AM
  #132
Resmarted's Avatar
Resmarted
Sweet man! Glad to see everything came out great!
I've run into road block after road block. California is a bish.
Old May 31, 2016 | 11:01 AM
  #133
meanz's Avatar
meanz
Yeah man she's been running pretty good. Really all I need is some sticky tires for the track and I can see what it will do.
Also this happened..
Old May 31, 2016 | 01:04 PM
  #134
Resmarted's Avatar
Resmarted
Damn you're goin in deep. I dont want to ruin the surprise so going a custom color? Or a nissan factory color?
Old May 31, 2016 | 07:42 PM
  #135
meanz's Avatar
meanz
It will be an oem z color with small twist. Hope it comes out good. Got to play with taywans gun tonight. Little bit of primer..
Old Jul 28, 2016 | 07:58 AM
  #136
meanz's Avatar
meanz
Z came out from paint looking pretty good.
Old Jul 28, 2016 | 08:02 AM
  #137
meanz's Avatar
meanz
So now she's back together and looking good. All till I heard a tapping comin from the engine. Got slightly worse. Me and tuan tore the engine down and found some new performance upgrades.
Inside of piston where the wrist pin goes.
Old Jul 28, 2016 | 08:14 AM
  #138
Highway Riding's Avatar
Highway Riding
Ouch sorry to see! How long did she last on TT?
Old Jul 28, 2016 | 08:27 AM
  #139
meanz's Avatar
meanz
Not really sure, but I've been beating this engine for 2 years now. So I got my money out of her. Hopefully ordering parts tonight for rebuild.
Old Jul 28, 2016 | 09:49 AM
  #140
Conway_160's Avatar
Conway_160
I saw you put the TT up for sale, are you keeping that route or going something different?
