Another Daily Driven Vortech Build
Old Jan 18, 2019 | 10:33 AM
  #521
bealljk's Avatar
bealljk
Originally Posted by BluestreamDE
If Aboodi can push 32psi on 11.1 and cams, i think well be alright as long as were taking the necessary precautions and using the best parts we can get. Granted i dont have Turbo Tuff rods abd 625+ head bolts/studs. My L19s should be fine, and Eagle under rates their H-Beam rods, Rated at 600hp but seem ppl push over 800whp with no issues on the VQ with ethanol or race gas. At most without belt slip (Whuch i believe there will be some) i will be at 25-26psi at 6600, plan to rev to 7100 if Vlad gives the go ahead and there is enough fuel on the table.
I have a habit of watching those dyno fail videos on Youtube so its got my nerves on edge lol
I though eagles were good to 800? I think one of the most understated fact of the eagles is that they are notable lighter than your traditional aftermarket rod.
I think dyno-fail videos are a false sampling of the aftermarket realm … I think a good tuner, a solid build, and running quality fuel is the best thing you can do. Does tihs happen - of course...but I think more often than not something breaks but doesn't grenade the entire engine.
Old Jan 18, 2019 | 10:49 AM
  #522
BluestreamDE's Avatar
BluestreamDE
I could of sworn i read they were 600hp rated of Eagle's webpage. Might of been wrong. Actually other sites from what i am seeing after a few hits on google say 750-800. I stand corrected.
True but even after you do everything you can to make sure everything is copasetic, you still worry about the "Unknown Variables". As long as i dont go into the dyno session with expectations, i wont feel bad if my pre targeted goals arent met.
Old Jan 18, 2019 | 12:30 PM
  #523
bealljk's Avatar
bealljk
oh yea! I hear ya...and you never know when you got the shtty part of the gas delivery truck. I do agree that you can only control so much but of what we can control I do my best to ensure it functions as intended!
Old Jan 18, 2019 | 12:34 PM
  #524
Conway_160's Avatar
Conway_160
I would have sworn they rated each rod @125-130whp, or ~750whp.
Your on E85 as long the tuner is not dumb and trying run 6* of timing you will be g2g.
Old Jan 25, 2019 | 09:25 PM
  #525
BluestreamDE
Not much of an update but changed up some cosmetic details. Changed up my windshield banner, Not sure how i feel about it, will let it sit for a few days. Car has been bada$$ besides that. Just waiting on Tune day.
Old Jan 26, 2019 | 09:13 AM
  #526
bealljk's Avatar
bealljk
tbh, I'm not a fan ... I like the 'nissan' ... I dont like the 'nismo'.
Regardless - some great shots of the car!
Old Jan 26, 2019 | 11:04 AM
  #527
BluestreamDE
Thanks B, the thing only costs 30 bucks so its not a loss if i peel it off.
Old Jan 26, 2019 | 11:07 AM
  #528
bealljk's Avatar
bealljk
The car still kicks *** ... and that's what matters
Old Jan 31, 2019 | 03:34 PM
  #529
BluestreamDE
Car heads back to National Speed tomorrow for 2nd Tune attempt. Besides the regapped plugs (.024-.025), Gates RPM Serpentine belt and pulley swap from the 3.12 to the 2.62, these are the only changes. Bringing a generic Gates belt of the same size just incase the RPM belt snaps.
Old Jan 31, 2019 | 04:39 PM
  #530
bealljk's Avatar
bealljk
updates every 3 to 5 minutes, right? In for results!!
Old Jan 31, 2019 | 08:36 PM
  #531
BluestreamDE
Updates won't be that frequent but I will make sure to make every detail is known. Just too damn nervous something will go wrong again. I am anticipating some amount of belt slip especially in the higher rpms. Last step is to get the carbonite coating on the 2.62 pulley if it happens. and if there is not enough fuel, I will let Vlad know to lower my rev limit. Not wanting to switch pulleys. I want to make the 2.62 work.
Old Feb 1, 2019 | 06:43 AM
  #532
0taku's Avatar
0taku
I guess we will see which rods will hold out longer, your Eagles or my K1 rods. I'm just glad there's a healthy supply of E85 where I'm at. (Winter blend here has been a steady 82-83% which is nice.)
Oh! Let me know how those RPM belts hold out. I was too scared because of the belt recoil after letting off the throttle from high RPM since the RPM belts don't stretch nearly as much as the Fleetrunners. (I'm on belt #7, have 2 spares in the trunk)
Old Feb 1, 2019 | 09:22 AM
  #533
BluestreamDE
​​​​​​​Got to the shop about 40 min ago, car is strapped down and ready to go.
Old Feb 1, 2019 | 12:06 PM
  #534
BluestreamDE
Well some bad news for those that like good news. On the 16th pull, i started to push coolant and the consensous is that the head gasket failed. Before hand, my coolant cap was pissing coolant on the first half pull, after replacing it, it seemed to remedy the problem.
I have L19 head studs installed and im not sure what happened. I remember before when i had my old setup with the SCi trim, i had the same problem, but i was running the ARP standard head stud kit. Perhaps my heads are warped? Im not sure why at 16lbs that the problems started to arise.
Either way leaving the shop discouraged, but the team at National speed were nothing but helpful. Even helped me get the car on the trailer.
Good news, its not a hole in the block.
Old Feb 1, 2019 | 01:05 PM
  #535
bealljk's Avatar
bealljk
Sorry to hear -
is the next step to get the heads machined?
Old Feb 1, 2019 | 06:17 PM
  #536
BigBlue's Avatar
BigBlue
Sorry to hear also! Hang in there Bluestream, you are putting in more than your share of effort so far and you'll get it worked out. I'm wondering possible deck surface of block and/or heads?
Old Feb 2, 2019 | 08:00 AM
  #537
Colombo's Avatar
**** man. I hate this for you. You got way more patience than me I woulda been sold everything haha. Keep at it tho itll be worth it in the end.
Old Feb 2, 2019 | 12:04 PM
  #538
0taku's Avatar
0taku
Yikes, that's upsetting to hear.
Hopefully it's something that isn't too major.
Old Feb 3, 2019 | 05:30 PM
  #539
OldManZ350's Avatar
OldManZ350
Wow, Sorry..... That Sucks
Old Feb 4, 2019 | 05:28 AM
  #540
eZg's Avatar
eZg
Condolences.......what brand Head gasket??
