My attempt for 500 whp
Old Sep 25, 2016 | 01:23 PM
bignmz04's Avatar
bignmz04
Default My attempt for 500 whp
I am trying to get my Zr to 500whp on a vortech.
The motor:
Arias 9.5-1 pistons
Pauter I-beam Rod
Port and polished
3 angle valve job
balanced and blue printed
bored .020 over
wsx dry film lubricant on all bearing/friction surfaces
heat treated coating on pistons, valves and combustion chambers
Micro polished crank
HKS head gasket
Nissan HR valve springs
Arp head studs, main studs, and rod bolts
ACL rod bearing, main bearing, and thrust washer
Pathfinder cooling mod
Fuel system:
DW 1200 injectors
walboro 485 pump
Admin tuning Dual feed return system
exclusively on e85
Forced induction:
Vortech v3 sci
287 pulley and fluidamper
GTM pulley mod
Kinetix SSV (new style)
TIMROD
Exhaust:
Invidia N1
Momentum cat delete y pipe.
Tuned on uprev.
I am making low 424 whp and 380lb/ft of torque in hot and humid Lousiana at 12 psi on an extremely conservative tune!
How do i get to 500?
Thanks in advance.
Attached Thumbnails My attempt for 500 whp-14441207_960232167437098_1067159033103068473_n.jpg
Old Sep 25, 2016 | 01:33 PM
Conway_160's Avatar
Conway_160
Your on E85, with a built motor crank up the timing and raise your redline to 7200ish.
Quick question why do all that work and not put good springs and cams in the car?
Old Sep 25, 2016 | 01:50 PM
BluestreamDE's Avatar
BluestreamDE
OldmanZ350 has a Treadstone TR1245 Intercooler and sees great gains from his car, if you are using the basic Vortech Intercooler or an eBay cheapy like me, your intake temps are probably very high from ambient under boost. Cooler air allows for more advance timing and in turn more power.
Old Sep 25, 2016 | 01:57 PM
bignmz04's Avatar
bignmz04
I bought the motor used. I would have gone with cams, but it was too good of a deal to pass up.
I was also told that the HR springs would be sufficient for my needs.
Cams are in the plans. Maybe by the end of the year.
Old Sep 25, 2016 | 02:03 PM
Conway_160's Avatar
Conway_160
Ok then lay on the timing since your on e85
Old Sep 25, 2016 | 05:21 PM
meanz's Avatar
meanz
Gonna be pushing that sci hard to get the power you want. I would send blower to Vortech for the si upgrade. It's cheap and makes great power. 550hp@17psi on my old setup.
Old Sep 25, 2016 | 05:38 PM
bealljk's Avatar
bealljk
if I said it once I've said it 1000 times...
oil cooler
probably not the reason you're not a 500 but a good measure...
Old Sep 25, 2016 | 05:55 PM
bignmz04's Avatar
bignmz04
oil cooler
I agree.
I have an oil cooler, stillen oil pan, and only use Amsoil 10w40.
I didnt list it, intitially, because i doubt that has anything to do with making power.
Old Sep 25, 2016 | 05:58 PM
bignmz04's Avatar
bignmz04
What was your pulley setup like?
How much did you get on the sci?
Old Sep 26, 2016 | 01:36 PM
OldManZ350's Avatar
OldManZ350
What IC do you have?
You will never make 500whp @ 12psi on your setup
1. change out the Intercooler to a TreadStone TR-1245
2. Change to a V2 Ti-Trim
3. change to a 34T/28T Cog setup
And you should be good for 625ish who Range
And YES, you can Advance the Ignition Timing a bunch more with E85
Hope this helps
"Also PAINT the Brackets on the TimRod Radius Rod Kit"
The motor:
Arias 9.5-1 pistons
Pauter I-beam Rod
Port and polished
3 angle valve job
bored .020 over
HKS head gasket
Fuel system:
DW 1200 injectors
walboro 485 pump
exclusively on e85
Forced induction:
Vortech v3 sci
GTM pulley mod
TIMROD
Exhaust:
Invidia N1
Tuned on uprev.
Thanks in advance.
Old Sep 26, 2016 | 08:32 PM
bignmz04's Avatar
bignmz04
Hope this helps
I am powdercoating a bunch of engine bay stuff once i get it dialed in.
I have the stock intercooler but i am about to order the one that you suggested, right now.
How much whp do you estimate (you would have the best guess) do you think i can get with the new intercooler and a lot more timing while still keeping the v3 sci head unit?
Old Sep 27, 2016 | 07:56 PM
OldManZ350's Avatar
OldManZ350
Will a quility Tune and E85 should be able to make 560-580whp IMO
You will need a free flowing Intake and a free flowing Exhaust to get that though.
And you need to step up the speed of the SC with the 34T28T Cog setup
Old Sep 28, 2016 | 03:22 AM
03threefiftyz's Avatar
03threefiftyz
I've got very good breather mods but I'm a little surprised that you are at 424whp making that kind of boost....
Granted we spent days on the dyno trying to get the powerband I wanted (road race car), but we peaked at 427whp on a 3.33 pulley (8.3psi) before backing it down to my class max of 410 (flat as a board from 6000-7100rpm). 2.87 and ethanol would put the car around 500whp w/o a whole lot of issue. This was on a dynamics fwiw.
Old Apr 6, 2017 | 05:41 PM
bignmz04's Avatar
bignmz04
well, motor showed low compression and some scoring. also overspun the crap out of that si.
getting a 11:1 comp motor built, c2 cams and upgrading to TI trim.
Old Apr 6, 2017 | 06:42 PM
CK_32's Avatar
CK_32
Well your running a conservative tune and low compression..
Run a strong tune or raise your compression.
Old Apr 6, 2017 | 08:25 PM
bignmz04's Avatar
bignmz04
I dont think i want to go higher than 11:1 especially with the TI.
You are right on the tune, however.
Old Apr 6, 2017 | 09:11 PM
CK_32's Avatar
CK_32
I didn't see you went back to a higher compression.
I only read the OP of 9:1
Old Apr 7, 2017 | 02:03 PM
bignmz04's Avatar
bignmz04
Yes, that was my original/current motor with a SI. The new motor will be 11:1 with a ti that wont be spun as high as the SI.
Old Apr 7, 2017 | 02:31 PM
CK_32's Avatar
CK_32
Idk I'd say you should be good. Especially if you follow about what everyone else here has offered for advice.
You got some good advice from some pretty prime members here.
freezeg35
Aug 26, 2005 11:56 AM
esemes
Jul 8, 2004 07:44 AM
