New numbers with more boost
Old Apr 23, 2018 | 06:18 AM
bealljk's Avatar
bealljk
Hey Meat - Are you running an OEM/CF drive shaft and/or OEM axles on you 800+ ft*lbs runs?
Old Apr 23, 2018 | 06:27 AM
meatbag's Avatar
meatbag
ACPT carbon driveshaft(G35 has 2 piece from factory) and DSS lvl9 axles.
Old May 16, 2018 | 12:56 PM
meatbag's Avatar
meatbag
Got some new fuel pumps on the way, going to see if it will hit 1200 on these turbos. If not ive got some 6766 i can throw on to test.
Old May 16, 2018 | 01:14 PM
bealljk's Avatar
bealljk
atta-boy, atta-kid!!!
Old May 17, 2018 | 12:24 AM
wizard's Avatar
wizard
Is there a build thread or spec list for your car anywhere? SO cool
Old May 17, 2018 | 07:24 AM
meatbag's Avatar
meatbag
I dont anymore, its nothing crazy besides the front mount turbo setup and the CJ intake manifold.
Old Jun 19, 2018 | 09:23 AM
meatbag's Avatar
meatbag
Was setting the boost control up with a 4 port solenoid this weekend and got a little more out of it and fuel pressure was not dropping nearly as bad with the DW400 pumps that I put in.
Old Jun 19, 2018 | 09:49 AM
bealljk's Avatar
bealljk
gooooooood lord!
Old Jun 20, 2018 | 03:30 PM
Tritan's Avatar
Tritan
I can't wait to join this club next dyno. I'm putting in a surge tank with twin Bosch 044 fuel pumps supplying AUS 1475 injectors.
Switching to AEM infinity E85 twin 4 port boost controllers as well....
how does your hood clear with that CJM intake ?
Old Jun 20, 2018 | 03:32 PM
Tritan's Avatar
Tritan
Justin, do you think any of your headgasket issues have to do with your closed deck block?
Old Jun 21, 2018 | 05:56 AM
meatbag's Avatar
meatbag
I wouldn't waste time plumbing and wiring 2 solenoids and just use a single.
Hood clears with the under bracing cut away right where the pipes come over the radiator. The radiator is shorter than stock too
Tougelabs
May 24, 2012 10:27 AM
350z006
Nov 26, 2009 06:52 AM
Chris@SP
Shop Builds
45
Sep 6, 2008 06:47 PM
daytona350zr
Aug 26, 2006 01:28 AM
