The journey for power w/ Powerlab, ProEFI, and ethanol
Old Aug 30, 2018 | 04:55 PM
  #41
WTFMike's Avatar
WTFMike
I'll hopefully have the housing back either tomorrow, if I'm lucky, or early next week.
Old Aug 30, 2018 | 06:24 PM
  #42
bealljk's Avatar
bealljk
that aint bad ... if it's tomorrow you got the WHOLE weekend to tie things together
Old Aug 30, 2018 | 08:11 PM
  #43
WTFMike's Avatar
WTFMike
Not quite the whole weekend. This Saturday is a religious holiday for me. It's the first Saturday of college football.
Old Sep 3, 2018 | 06:38 AM
  #44
WTFMike's Avatar
WTFMike
The turbo is back on. We haven't turned it up all the way yet. However, the car is moving out on 22psi. Pure turbos told me this turbo should be able to do 30 psi. The good news, is my exhaust back pressure ratio has dropped pretty dramatically. I'll let thatv35guy post more on that. But we have a lot of exhaust back pressure data on our cars with the 62mm turbine wheels and now with the 66mm turbine wheel.
Old Sep 3, 2018 | 09:16 AM
  #45
bealljk's Avatar
bealljk
nice ... where does 30psi put you on your compressor map?
Old Sep 3, 2018 | 11:40 AM
  #46
WTFMike's Avatar
WTFMike
I don't have compressor map for this turbo. The 64mm compressor wheel is Pure Turbos own design. So it's going be different from Precision's 6466. Pure Turbos says this setup is good for 900whp. However, I don't think it will do that on a VQ. I'm pretty sure it should do low 800's though.
Old Sep 3, 2018 | 12:11 PM
  #47
bealljk's Avatar
bealljk
respectable for sure ... Is 30psi is pushing you out of your efficiency range (probably not on a blower that size). Regardless - that's pretty stout - curious and excited for ya!
Old Sep 3, 2018 | 12:32 PM
  #48
WTFMike's Avatar
WTFMike
When I was talking to PureTurbos about upgrading my GT3582r to the Pure 6466, they told me their turbo won't start shining until 20psi and should be able to run up to 30. So 30 is probably on the upper end of it's efficiency range. Come October, when it cools off a bit more, I'll rent some dyno time and see how much power the car is making. I think I'm going to settle around 750whp, which should be 25ish psi, mainly because I'm using Eagle rods. I'm in the last semester of my degree, so next year I'll hopefully be gainfully employed. Then I can spend some $ to build another block with some better parts, then turn up the turbo for all it's worth. Thankfully my wife hasn't complained about the $ I've spent on the car while I've been in school.
Old Sep 6, 2018 | 05:56 PM
  #49
WTFMike's Avatar
WTFMike
So, does anyone know where I can buy a new connector for the coolant temp sensor?
Old Sep 6, 2018 | 07:39 PM
  #50
bealljk's Avatar
bealljk
I got a few of them floating around...you just need the pigtail?
Old Sep 6, 2018 | 08:41 PM
  #51
WTFMike's Avatar
WTFMike
Yes. I actually just got one off a guy locally. I'm having issues with the temp reading erratically. I replaced the sensor. However my issue came back. So with the car running whenever i touch the connector i can see the temp jump around. So I'm going to swap on a new connector and see if that does anything for me. Hope it does.
Old Sep 12, 2018 | 10:51 AM
  #52
WTFMike's Avatar
WTFMike
So, thatv35guy and I were out messing with my car the past couple of nights. On Monday night the car was over boosting. Fortunately the ProEFI kicked in and cut ignition. Turns out the set screws that hold the WG diaphragm to the plunger had backed out. So I put some blue locktite on them and reinstalled the WG. Last night we got the car back out and hit 20, 24, and 27 psi. The car pulls like a freight-train. I bought a Dragy so I could get some good data with the car. We were in Mexico attempting to do some 60-130 runs and the car apparently doesn't like going into 5th under power. I tend to power shift the car pretty hard 2-3-4 and it takes that just fine. But I couldn't get it into 5th without killing the time. I think a 3.3 rear gear may go into the car soon. Then I should be able to do 133 in 4th.
Old Sep 12, 2018 | 02:52 PM
  #53
Conway_160's Avatar
Conway_160
Have you tried to realign your shifter to see if you can get it to go into 5th? I was having the same problem and realigned it and worked like a champ, but i'm also making idk 1/8th your power LOL.
Old Sep 13, 2018 | 01:06 PM
  #54
WTFMike's Avatar
WTFMike
I haven't tried realigning the shifter. Maybe this weekend. All my logs are looking real good. I think when I get the car on the dyno, probably next month, we might try 30 psi. You know, for science.
Old Sep 15, 2018 | 06:15 AM
  #55
WTFMike's Avatar
WTFMike
Welp, I may have found the limit of the competition 6-puck clutch...
Old Sep 15, 2018 | 07:03 PM
  #56
BluestreamDE's Avatar
BluestreamDE
What happened? I'm running the Competition Stage 3 segmented clutch atm. Is it slipping at 27psi?
Old Sep 15, 2018 | 08:13 PM
  #57
BoostedProbe's Avatar
BoostedProbe
Is that a T3 housing? If so, have you measured your EBP at 27psi?
Old Sep 15, 2018 | 11:42 PM
  #58
thatv35guy's Avatar
thatv35guy
Yeah, it’s the same 1.06 T3 housing he was using with the GT3582R, just machined by Pure Turbos to accept their 66mm turbine wheel.
Car has a ProEFI exhaust bp sensor in the turbine housing. I’ve been logging the exhaust bp from 20 psi onwards, it’s been very consistent at 20, 24, and 27 psi, it’s seeing roughly 26-27 psi of exhaust bp (almost a 1:1 ratio). It was actually so low I made sure the EBP was rising consistently at light/part throttle situations.
For reference, his car has an unmodified PowerLab kit, Megan header, a 3” straight through exhaust, and the Pure GT35R/6466 turbo upgrade.
Old Sep 15, 2018 | 11:44 PM
  #59
thatv35guy's Avatar
thatv35guy
False alarm, haha
Clutch is holding up, I’ll let OP explain but we got his car sorted out and holding 27 psi earlier tonight.
Old Sep 16, 2018 | 06:24 AM
  #60
WTFMike's Avatar
WTFMike
Well, you were right. And THANKS! I tore it down to the shifter plate and all the bolts were all basically backed out. It's odd that it happened. I haven't had the trans out of the car in 4-5 years.
The other night when I was shifting the car would hesitate at gear changes. It seemed like the clutch slipped then caught. Turns out the trans just wasn't going into gear completely. I did the shifter re-alignment and we beat on the car last night pretty hard.
Yup, it's the T3 1.06. With the GT3582R we were seeing EBP in low to mid 40's. So I had a ratio of just over 2:1 EBP to boost. With the 66mm turbine wheel my EBP has dropped to 26. So I'm seeing a 1:1 EBP to boost ratio.
