Want and even tighter belt on your vortech/supercharger setup?
Old May 27, 2020 | 11:24 AM
350z006's Avatar
350z006
Default Want and even tighter belt on your vortech/supercharger setup?
Its been a while and my car has been a garage queen but I've finally gotten back to working on the car and fighting the good fight against...belt slip! Those of you guys running Vortech kits with bigger blowers know my pain.
With my big blower YSi setup (the older heavier non billet impeller) and a 34/28 cog setup on a 2.75 pulley I've had good days and bad days with belt slip; OldManZ's Timrod helps and tightening your belts to the limit helps too, but some days the 6 ribs just aren't enough even at maximum tightening with the stock belt adjuster, so I've been experimenting getting one sized smaller belt belt and breaking it in/stretching it until I can just get it over the pulleys, but its a pain in the butt to do.
So I decided to modify the belt adjuster on the VQ35DE so it can easily take a smaller belt, that way I don't have to break in and stretch the smaller belt:
Typical VQ35DE belt adjuster:
With pulley taken off:
With a bit of grinding you can make the maximum loosening adjustment point lower, allowing you to put smaller belts you can tighten more:
So there you have it, pretty simple and easy to do; hopefully at my next tune I'll be able to maximize the YSi properly and get back into the upper 25+ psi range; next thing is maybe switch to the lighter billet YSi impeller, but after that I'm not sure what else I want to do really. It's already got way more power than I can handle at my age lol.
Old May 27, 2020 | 01:27 PM
bealljk's Avatar
bealljk
fncken hero … slow clap!
Otaku - just do this!!!! you don't have to compound FI systems now!!!
Old May 27, 2020 | 02:22 PM
350z006's Avatar
350z006
Oh...and do you yourself a favor and use a tungsten carbide bit if you use a dremel grinder...I didn’t have one and used an aluminum oxide bit...took way longer than it should have...
Old May 27, 2020 | 03:03 PM
0taku's Avatar
0taku
Subbed for results.
Old May 27, 2020 | 10:10 PM
OldManZ350's Avatar
OldManZ350
Good Idea!
Old May 27, 2020 | 10:13 PM
OldManZ350's Avatar
OldManZ350
Do you have a Larger Crank Pulley?
Old May 28, 2020 | 08:53 AM
350z006's Avatar
350z006
yes I run the Ati crank
Old May 28, 2020 | 03:45 PM
OldManZ350's Avatar
OldManZ350
Well you could go to a 34/27, 2.87 Serp that is very close blower speed, but less slip. you do have to machine the nose of the pulley.
this would help.
I'm surprised you are only getting 25psi with you set up. you must have a fair amount of belt slip.
Old May 29, 2020 | 10:59 AM
350z006's Avatar
350z006
this would help.
There's a 27 cog vortech pulley out there? That would be useful...
The YSi cast impeller is pretty heavy...I'm sure with the YSi B Billet impeller it will have much less belt slip...
Old Jun 1, 2020 | 07:47 PM
OldManZ350's Avatar
OldManZ350
Yes! 27 Tooth
"NEW MOTOR BUILD WITH V7-YSI UPDATES COMING 2020"
CP PISTONS 11 to 1, CARILLO RODS, HEADWORK, KELFORD 272 CAMS
Old Jun 2, 2020 | 11:09 AM
350z006's Avatar
350z006
Yes! 27 Tooth
That setup looks sweet; can't wait to see the results...is that a YSi-B?
Old Aug 11, 2021 | 11:01 AM
OldManZ350's Avatar
OldManZ350
Sorry, Never gave you an answer.....
No, it's a Standard YSI
Check out my Thread....
TimRod
Calinismo350z
Jun 26, 2012 01:43 PM
vTxSpikeZ
Mar 10, 2010 02:53 PM
Blackbird CPV35
Apr 10, 2009 08:52 AM
RA11325
Aug 10, 2006 02:56 PM
mcduck
Dec 3, 2004 09:03 PM
