HKS supercharger build
Old May 19, 2023 | 12:48 AM
  #261
DarkZ03's Avatar
DarkZ03
Currently debating as to what direction I want to go in.
Because of the current state of economy, the long blocks from Soho went up dramatically (like I can buy another supercharger kit with the difference, dramatically)
Although the idea was nice in my head, that's a lot of money, I feel like all I really need is a spare engine to throw some rods and pistons into (or even in mine).
I wish I had access to a nicer garage and clean spot where I could build my own engine, but I do not.
If I'd have to guess right now, I'd say I'll target 2025 for finishing the project.
Old May 19, 2023 | 11:07 PM
  #262
Timboj's Avatar
Timboj
Totally get it, man. On top of everything being more expensive in general, the AUD-US exchange has taken a beating so I'm in no hurry to get my remaining parts, which is why I still haven't gotten the block inspected. Not a great time for car modding.
Old May 20, 2023 | 12:14 PM
  #263
VQplatform's Avatar
VQplatform
@Timboj Is traction a serious issue at the power that you are currently at? I know you are running a 3.9 final drive however, I'm running stock gearing so hopefully traction is better LOL. Looking to upgrade to Michelin PS4S with 285s in the rear as I already have the other rear end mods done aside from a LSD (also going with Quaife). Hoping traction isn't too big of an issue
Old May 20, 2023 | 11:27 PM
  #264
Timboj's Avatar
Timboj
@VQplatform It breaks traction very easily in 1st/2nd. Under the right conditions I'll bet 3rd is possible too. Better tyres than my Kumhos will obviously help and if I do get a little more into drag racing, I'll end up playing around with launch control.
For anyone in the know, is there any real benefit to recirculating air from the blow-off valve? Seems to me like it just creates unnecessary pressure in the intake pipe (and also muting my pssst).
Old May 21, 2023 | 04:28 PM
  #265
DarkZ03's Avatar
DarkZ03
In theory it's metered air but you aren't using a MAF so I think you should be good? Might take slightly longer to build boost.
Old May 21, 2023 | 04:58 PM
  #266
Pazich's Avatar
Pazich
It's not metered on our HKS setups, the bypass valve is before the MAF. Not sure on performance benefits but it will definitely be way noisier since it's a bypass on a supercharger as opposed to a blow off on a turbo. I'd be curious to know though if there's any benefits.
Old May 21, 2023 | 05:31 PM
  #267
Timboj's Avatar
Timboj
Yeah it's pre-MAF so wouldn't be metered anyway. I don't think there are any downsides, but might not be any upsides either. I'll run without recirc for a while and see if it makes a difference.
Old May 21, 2023 | 09:34 PM
  #268
VQplatform's Avatar
VQplatform
@Timboj I do think the 3.5 final drive will help you greatly with traction and your 1/4 mile times. I hope that I see better traction running the 3.5 with Quaife LSD. Have you done any recent dyno runs? Curious to see what your torque numbers are, I realized your cams probably made a big difference with FI numbers wise, do you think your numbers are pretty much in-line with your set up? I have seen people run 400whp/400wtq on a completely stock block
Old May 21, 2023 | 09:54 PM
  #269
Timboj's Avatar
Timboj
A lower FD will probably make the car more driveable after the next power bump, but it's not necessary yet. With 400hp and a 3.3 FD you'll still break traction in 1st and 2nd if you want to. Improving my drag times is mostly just practice on the launch. That and/or dialing in a launch control.
Curious as I am I haven't been back to the dyno. One of Z1's employees made made 427whp @12psi, so yeah I could make more power (more boost) but I'm fine with where it is.
Old May 21, 2023 | 10:02 PM
  #270
VQplatform's Avatar
VQplatform
Wow, car is quite beastly with the power its making, I'm not looking for anything past stock block limits actually just curious on the variation but that could be due to different dynos and such. Hopefully I can still reach 380whp/380wtq without cams as I'd like for my powerband to stay to the left as much as possible but I think it should be realistic on this kit given several testimonies. What RPM do you feel boost build?
Old May 24, 2023 | 07:13 PM
  #271
DarkZ03's Avatar
DarkZ03
Keep in mind the dyno will basically be what the car is now amplified, the kits aren't like turbos where it can shift power left, max power will be near redline and max torque should be somewhere around the crossover on a dyno graph.
Old May 24, 2023 | 08:43 PM
  #272
VQplatform's Avatar
VQplatform
True I was mainly referring to the cams shifting torque to the upper powerband but the kit still makes a lot of power at the very low end which is a big advantage over the vortech kits.
Old May 25, 2023 | 09:28 AM
  #273
OldManZ350's Avatar
OldManZ350
Go To Mazworx.....
Much Higher Quality, Much much better Price!
Old May 25, 2023 | 01:30 PM
  #274
DarkZ03's Avatar
DarkZ03
Originally Posted by OldManZ350
Go To Mazworx.....
Can you elaborate on the quality comment?
I have hardly heard of them but i do know Soho and all they do, including the exclusive stuff for high boost applications
Old Jun 2, 2023 | 04:00 PM
  #275
OldManZ350's Avatar
OldManZ350
Mazworx Build Race Motors & Race Cars of all Kinds..... go to there website, call Mark @ Mazworx
Quality is above and beyond.....
I also got a Complete Spec list of all Machining.
+/- .0005" Near Perfect. You can trust that's it will be done Right!
Although I assemblied my motor, Mains & Rods came out +/- .0002" yes 2 ten thousands of an inch
Cyl Bore came out +/- .0001"
Soho is secretive..........
Old Jun 2, 2023 | 06:17 PM
  #276
DarkZ03's Avatar
DarkZ03
Cool, thanks.
So they built your current engine I assume?
Old Jun 2, 2023 | 10:35 PM
  #277
OldManZ350's Avatar
OldManZ350
No, Mazworx did the Machine Work Only on my Motor, I Built it.
But they do build short blocks and long blocks.
Cool, thanks.
Old Jun 3, 2023 | 05:19 PM
  #278
DarkZ03's Avatar
DarkZ03
Gotcha, I didn't see a longblock option, I guess I'll reach out. Thanks!
Old Jun 7, 2023 | 12:52 PM
  #279
Escobar's Avatar
Escobar
I just emailed Mark, short block 5k, long 15k
Old Jun 8, 2023 | 06:36 PM
  #280
DarkZ03's Avatar
DarkZ03
Cool, I'll have to call. I want a very specific brand set, and any OEM stuff I prefer new.
Want Boostline rods and Wiseco pistons, for the bottom end.
