5AT (automatic transmission) Owners With Forced Induction Please Read
Old Jul 2, 2009 | 09:27 AM
  #321
coachk's Avatar
coachk
mrg.... No one should be allowed to touch the boost settings, chop off their fingers
Good luck at the track and look forward to your results, with a vid of course
Old Jul 2, 2009 | 11:11 PM
  #322
mrg1981's Avatar
mrg1981
Originally Posted by iStan
Thank god it was a 'simple' fix. Crank the boost up!
No kidding! Sorry to scare you in my PM. My car wouldn't shift and I was very concerned, to put it lightly.
Old Jul 2, 2009 | 11:13 PM
  #323
mrg1981's Avatar
mrg1981
LOL. Actually, only one person is allowed to touch my tuning; Jason Seibel from Pro-EFI. The funny part is, he's the one that changed it! I think he just forgot what levels I had it set at and thought that 15 was my high setting, rather than low. Either way, he needs to have some time with the car and will in a few weeks. I also will dyno it again, since it hasn't been dyno'd with a built transmission (only a "pretend" built transmission ).
Old Aug 10, 2009 | 10:03 AM
  #324
06g35meister's Avatar
06g35meister
Originally Posted by CeBrwn5454
A buddy and I installed my Transgo kit. It was done on jack stands...garage type setup. The whole process beginning with draining the ATF ending with refilling the tranny...took around 8 hours. Neither of us had ever worked on an automatic tranny before. You can do it if you research it enough and print out a few different instruction booklets.
and what gains! that thing shifts harder than a dick during sex!
Old Aug 29, 2012 | 01:23 AM
  #325
SkyZ33's Avatar
SkyZ33
So I read though all, I guess just Transgo Valvebody Upgrade kit and no need Torque Converter then?
About to install Vortech
Old Aug 30, 2012 | 06:30 AM
  #326
streetzlegend's Avatar
streetzlegend
What I do in my own car is keep the Torque Converter unlocked when racing it. I have a switch that interrupts the signal of the wire going into the TC Lock up solenoid. The reason I do this is because while in boost the lock up clutch(s) may (depending on how much torque of course) slip, which will then cause more heat, debris in the fluid, etc...
Yes, running it without the TC being locked will produce more heat but its better than heat coming from slipping clutches/band.
Old Aug 30, 2012 | 07:57 AM
  #327
SkyZ33's Avatar
SkyZ33
Do I need to pull the tranny out to upgrade ValveBody using Transgo?
Because the shop is oging to charge me for pulling off the tranny.
Old Aug 30, 2012 | 08:05 AM
  #328
SxExCx's Avatar
SxExCx
^ no, they only have to remove the fluid pan.
Old Aug 31, 2012 | 01:26 AM
  #329
SkyZ33's Avatar
SkyZ33
Any idea how much labor should cost to install Transgo VB? Thanks!
Old Aug 31, 2012 | 02:39 AM
  #330
maXmood's Avatar
maXmood
Under Boost!
i've done the VB upgarde, and IMO don't go for it if u have 350whp+... it doesn't do much really.. you'll be better off beefing up ur tranny instead, or even swap in a 6MT.
upgrading shouldn't take more than couple of hours. i'd say 4 to 5hrs including removal/installation of the VB.. cost wise, i paid around $200, but mechanics here charges are different.
Old Aug 31, 2012 | 07:31 AM
  #331
kloudak47's Avatar
kloudak47
I had mine done locally (WA) and it was 7-8 hours labor. Depending on the labor rate of the mechanic expect around ~7-800 for install.
Transmission definitely does not come out of the car for the install so if you spoke to a shop, received an estimate and that's what they told you go then I'd go somewhere else.
Old Aug 31, 2012 | 01:40 PM
  #332
SkyZ33's Avatar
SkyZ33
Post
Old Aug 31, 2012 | 04:44 PM
  #333
kartkid's Avatar
kartkid
It is easy as long as you follow the directions.
The trans fluid is not cheap.
If you have up-rev tune just try the reprogramming
with your tuner it works great. I installed the valve body
kit as well as having the reprogramming.
Big difference and you will need an external trans cooler as well.
Old Sep 3, 2012 | 12:04 AM
  #334
SkyZ33's Avatar
SkyZ33
Can you recommend me the shop? I need to upgrade my VB too. I live in Lynnwood/Edmond, thank =)
Old Sep 3, 2012 | 08:43 AM
  #335
herrschaft's Avatar
herrschaft
If installed correctly, the benefit should be noticeable no matter how much power the car has. I'm at 450whp+ and the Transgo VB works great.
Old Sep 3, 2012 | 12:52 PM
  #336
Eno's Avatar
Eno
Yeah shifting is shifting. What the vb wont do is give you any additional capacity to retain torque. Get the vb to tighten your shifts- not your clutchpacks.
Old Sep 7, 2012 | 12:27 AM
  #337
SkyZ33's Avatar
SkyZ33
what kinds of tranny fluids you guys used? Thanks!
Old Jan 1, 2014 | 11:06 PM
  #338
iStan's Avatar
iStan
ZR
Reviving an old thread. I cannot remember which of the hard lines is in or out. Does anyone remember?
Also, has anyone replaced the hard lines? My trans cooler currently runs a line clamped onto the hard line. I'm going to look in the FSM but I would be interested in hearing from anyone who has already done this.
Old Jan 2, 2014 | 06:16 AM
  #339
ogiehooker's Avatar
ogiehooker
Default lines
replaced lines with SS braided -6an....I can't remember why, but I had to have some spcial fittings welded to attach the an lines to the at body...regardless, it was easy with a welder....I cant remember either which is in or out...
GL
Old Jan 2, 2014 | 04:40 PM
  #340
- bigc -'s Avatar
- bigc -
The attached diagram shows which one is which.
My hard lines were replaced with braided line.
Attached Thumbnails 5AT (automatic transmission) Owners With Forced Induction Please Read-atdiag.jpg
MAsSIVrOOM
Oct 20, 2023 10:50 AM
burglapfd
Dec 6, 2020 01:04 PM
Tochigi_236
Sep 27, 2015 03:40 PM
