5AT (automatic transmission) Owners With Forced Induction Please Read
Old Apr 30, 2009 | 05:26 AM
  #241
nothix's Avatar
nothix
Got my Transgo Valveboy kit from GTM in, and the shop is almost finished with the rebuild.
Old Apr 30, 2009 | 04:29 PM
  #242
BaZooKa's Avatar
BaZooKa
GL with the build and give us more reviews ,, i just installed my B&M tranny cooler, its great!! very good cooling and awesome quality, you should go with it ,,
ive also noticed that before the tranny cooler sometimes under the center console you will feel its a bit hot (maybe in kuwait only) but after the tranny cooler, the in-cabin heat is reduced alot!
Old May 19, 2009 | 12:23 PM
  #243
nothix's Avatar
nothix
Got my car back and it shifts a lot harder.
Top of the shifter doesn't get as hot as it used to but still gets warm after 30+min of driving.
The higher stall converter makes it drive kind of funny.
I don't think I would get this mod unless it is really a drag car.
Overall its an big improvement, but now I'm going through tires like crazy.
I'm considering moving on to a MT for a more versatile setup and to support more HP.
Old May 19, 2009 | 01:41 PM
  #244
Jeff92se's Avatar
Jeff92se
How is it for normal driving? I'd love the firmer shifts but not if the shifts are too jerky or harsh during crusing/commuting.
Old May 19, 2009 | 02:32 PM
  #245
fowlman01's Avatar
fowlman01
mine shifts normal in drive.
Old May 20, 2009 | 02:05 PM
  #246
iStan's Avatar
iStan
ZR
I think it's time for me to bite the bullet..
Old May 20, 2009 | 03:04 PM
  #247
BaZooKa's Avatar
BaZooKa
Mine to,, normal driving = normal shifts
Old May 20, 2009 | 08:44 PM
  #248
nothix's Avatar
nothix
ditto, normal driving is not affected.
As for the TC, it seems like its just slipping until it hits the 3k mark, or like its bogging.
Maybe its a tuning issue, but I never had this problem before.
I've noticed that since its gotten hotter out, my AFR is low 11, high 10; before it was mid-high 12s
Old May 20, 2009 | 11:40 PM
  #249
BaZooKa's Avatar
BaZooKa
nothix what TC do you have ?
Old May 21, 2009 | 08:58 AM
  #250
rcdash's Avatar
rcdash
I went down from a TC stall of close to 4k back towards 3k to get back more of the stock feel. Even with the very high stall converter, it should catch very early on and although it feels "mushy" below the stall point (because it's designed to slip below that), you should be able to pick up speed with very little applied throttle, keeping rpms around 2000.
Old May 21, 2009 | 05:40 PM
  #251
Zbee's Avatar
Zbee
I have the valve body upgrade an just got a code P1759. It's a front brake soleniod code. You you think this code is related to the VB upgrade?
Old May 22, 2009 | 01:09 PM
  #252
nothix's Avatar
nothix
thats exactly how it feels, thanks for clarifying that nothing is wrong with my tranny =)
Almost feels like boost/vtec kicking in at 2800rpm (Stall)
  #253
nothix's Avatar
nothix
doubt it
Old May 22, 2009 | 02:36 PM
  #254
fowlman01's Avatar
fowlman01
Originally Posted by nothix
doubt it
+1
Old May 23, 2009 | 03:22 PM
  #255
BaZooKa's Avatar
BaZooKa
Dont think so, where did you do the upgrade ?
Old May 25, 2009 | 05:38 AM
  #256
Zbee's Avatar
Zbee
I got all my upgrades at AAM except for a new tune for my 9 lbs. pulley which I got at Function Tuned. I think the UTEC may be the culprit. I get an EVAP code every time I fill the tank, but this P1759 code is the first time I got it. And to be fair, I was driving the car hard a laying wheels all over the place. I cleared the codes last week and they have not returned thus far.
Old May 25, 2009 | 11:02 AM
  #257
mrg1981's Avatar
mrg1981
I just got my transmission rebuilt and put back in a few weeks ago. It is a HUGE difference from stock. I will re-dyno, but with this transmission putting the power to the ground (as opposed to slipping), it feels like 50-100 WHP gain! The transmission is predictable now as well. Before it was firm then slow and mushy and you never knew what was going to happen.
So far the pros and cons.
Pros:
1. Firm, quick shifts
2. Reliable and predictable
3. Way more power gets to the wheels
4. Drives smoothly during normal driving
Cons:
1. Going to cost me more for tires; I need something stickier
2. I can haz traction plz?
Here is what was done to my transmission:
Alto Direct Power Pack Kit
Alto Input Power Pack Kit
Alto Hi-Low Reverse Kit
Alto Reverse Brake Kit
Alto Seal & Gasket Kit
Nissan Brake Bank (For 03-06 350z VQ35de Transmission)
Trans Go Valve Body Kit
Pro Torque Converter
Nissan 350z Front Pump
Nissan Input Piston & Drum Assembly 350z
3rd Sun Gear Assembly
Built Valve Body
Built Transmission
Labor to remove and re-install transmission
Old May 25, 2009 | 02:28 PM
  #258
rcdash's Avatar
rcdash
So far the pros and cons...
In other words, it now works! The way it should have the first time around. Congrats! Now you just have to hold on and flick your finger while you watch the world turn into a blur around you.
Old May 25, 2009 | 04:04 PM
  #259
iStan's Avatar
iStan
ZR
Old May 25, 2009 | 08:35 PM
  #260
mrg1981's Avatar
mrg1981
Yea, that's a good way to put it! The paddle shifters are awesome, btw!
Is it normal that my 1/4 times got way worse due to traction issues? At this boost with the stock trans, I was putting down 525. I'm thinking it may be over 575 or 600 WHP with the new transmission and I was running on stock tires (*edit street tires) with 35 PSI. I was running like 14.1 at 97mph with a 60' of about 2.5-2.9.
Last edited by mrg1981; May 26, 2009 at 07:32 AM. Reason: street tires, not stock tires...ooops
