VORTECH Problems.........Help Please!
Old Mar 29, 2004 | 08:25 PM
AmyCroft's Avatar
AmyCroft
Originally posted by fluidz
You called it...........just ran out to check my intake off the plenum and sure enough it blew off...................WHOOOOOOO i am releived.............thank you all so much for the help...........but i still dont understand the starting problem?
Good Catch JesseEnglish:
Have fun and keep us posted.. FluidZ
Cheers Amy -
Old Mar 29, 2004 | 08:46 PM
basam350z's Avatar
basam350z
Can Technosqaure ECU even read boost and changed the fuel and ignition maps dependent on boost?
Old Mar 29, 2004 | 08:48 PM
jesseenglish's Avatar
jesseenglish
No, it can't, thus no upgrading without getting your ECU reflashed.
Old Mar 29, 2004 | 08:53 PM
AmyCroft's Avatar
AmyCroft
Default O.K.
Originally posted by jesseenglish
LOL, settle down, it'll be alright. This is similar to the Crawford Vs. Kinetix arguments. It's not worth your time. I've stopped discussing the ECU thing entirely because it just leads to someone getting their panties in a bunch.
O.K.
fluidz's Avatar
fluidz
Originally posted by zimbo
So it was indeed the hose that goes from the plenum to the SS box? Glad you found it!
--Steve
It was the Intake off the throttle body that blew off
Old Mar 29, 2004 | 09:51 PM
12SecZ's Avatar
12SecZ
Welcome to FI,
Isn't it fun?
Glad you found the problem, I am constantly checking my hoses and belts. What guages do you have boost and wideband?
Old Mar 30, 2004 | 07:13 AM
fluidz's Avatar
fluidz
Originally posted by 12SecZ
Welcome to FI,
yes 12sec.........i will clean her today real good and get some nice pictures of everything complete including the gauges.
Old Mar 30, 2004 | 03:52 PM
fluidz's Avatar
fluidz
ok the problem was not fixed, still wont stay running...........should i disconnect the battery for awhile?
Old Mar 30, 2004 | 04:00 PM
jesseenglish
You can try, but since one thing came disconnected who's to say something else didn't. Have you checked all the vacuum lines connections to ensure nothing else popped off?
Old Mar 30, 2004 | 04:08 PM
fluidz's Avatar
fluidz
ya where do i start?
Old Mar 30, 2004 | 04:15 PM
baptist's Avatar
baptist
Good luck Fluidz, just keep yer cool, it will be something daft. I'd just trace the flow of air from the S/C as it would go through the system and try to look at every thing along the way.
You'll get it.
Old Mar 30, 2004 | 05:57 PM
fluidz's Avatar
fluidz
now the car is doing the following.............turn key and it just turns over and over.............then try again and it starts and runs for 3 seconds then dyes..........could this be a MAF sensor problem or a ecu issue with the SS Box? Sure it could, sh*t
Old Mar 31, 2004 | 03:49 AM
baptist's Avatar
baptist
Can anyone help the man?
Must be something daft Fluidz, how far away are comptech?
Old Mar 31, 2004 | 06:14 AM
fluidz's Avatar
fluidz
taking it back to them today
Old Mar 31, 2004 | 08:41 AM
narkotic's Avatar
narkotic
Yeah it sounds like your car is going into limp mode, and that your MAF is hosed.... good luck man
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
