Metal Head Gaskets To Lower Compression?>
Old Apr 1, 2004 | 07:55 PM
bigern1970's Avatar
bigern1970
Default Metal Head Gaskets To Lower Compression?>
Does anyone know of a company making metal head gaskets to lower the compression on the Z . please let me know.
Old Apr 2, 2004 | 05:55 AM
etx's Avatar
etx
Nope. But most places can custom make them if you have a gasket for them to look at and some technical specs on the motor.
Old Apr 2, 2004 | 06:27 AM
SSR Engineering's Avatar
SSR Engineering
Default Re: Metal Head Gaskets To Lower Compression?>
Ohh, you mean a cheater gasket... Try takakaira.com or it might be takakaira.co.jp
Old Apr 2, 2004 | 11:58 AM
LaPuLaPu's Avatar
LaPuLaPu
Default Re: Re: Metal Head Gaskets To Lower Compression?>
Why are you strongly against using a gasket to accomplish a lower compression? I know a handful of people who have used gaskets to lower their compression and had great success. Ok, besides the point of it being cheap, so what.... I’d just like to hear your 2 cents.
Old Apr 2, 2004 | 02:59 PM
G35SC T.T.'s Avatar
G35SC T.T.
Default Re: Re: Re: Metal Head Gaskets To Lower Compression?>
he didnt say cheap he said cheat
Old Apr 2, 2004 | 10:51 PM
SSR Engineering
I never said it was cheap, it's just the cheater method . It works, but when you tare the heads off this beast minus well just replace the pistons and rods while your there
Old Apr 3, 2004 | 07:50 AM
bigern1970's Avatar
bigern1970
Default Re: Re: Re: Re: Metal Head Gaskets To Lower Compression?>
If i could remove the head and just pop out the pistons i would but it take rebalancing the system( bottom end) but I have had much success with the HKS headgaskets when turbocharging acuras.
Old Apr 3, 2004 | 08:46 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the ones we had done are all ready for production now - I'll try to find out the compression offerings we will have this coming week for you guys
Old Apr 3, 2004 | 09:02 AM
SSR Engineering
Awesome, what kind of pricing are you guys offering with your head gaskets?
Old Apr 6, 2004 | 05:51 PM
slay2k's Avatar
slay2k
Just so you know, it's "might as well" and not "minus well". I bet you've spent countless hours of your life trying to figure out why a "minus well" would mean what you think it meant. =)
Old Apr 6, 2004 | 09:43 PM
spazpilot's Avatar
spazpilot
I would not go this route just to lower compression to raise boost. Not a good idea!!
Old Apr 6, 2004 | 11:25 PM
Mr B's Avatar
Mr B
How thick of a head gasket do you need to lower compression from 10.3 to 9.3?
Old Apr 6, 2004 | 11:37 PM
D'oh's Avatar
D'oh
Elaborate, please. Any specific reasons, data, calculations, or is this a gut feel?
Thanks,
D'oh!
Old Apr 7, 2004 | 06:11 AM
PoWeRtRiP's Avatar
PoWeRtRiP
i was under the impression that a headgasket could only lower your compression by a few .1 so it would make me feel more comfortable at low boost but i would not rely on that to crank up the boost safely.
Old Apr 7, 2004 | 06:19 AM
jesseenglish's Avatar
jesseenglish
If you could get the engine info... Bore, stroke, combustion chamber volume, deck height, valve relief volume we could figure that out. I've never seen any specs on that kind of info though.
Old Apr 7, 2004 | 12:18 PM
Mr B's Avatar
Mr B
Haha, I have no clue where I could find that info either. Maybe I should bug Jeff or Jason@Performance.
Old Apr 7, 2004 | 02:10 PM
G3po's Avatar
G3po
Default head gasket
Generally the reason why lowering compression on a modern street engine via a "thicker head gasket" is not recommended is that it negatively alters the "squish volume ". Increasing the squish volume can reduce the Combustion chambers tolerance to detonation (even if the CR is lowered slightly). Lowering CR via properly designed dished pistons is the recommended method.
If you want to know what "squish volume " means look in the thread about forged internal and lower CR or consult one of the Corky Bell boost books.
Old Apr 7, 2004 | 02:55 PM
spazpilot's Avatar
spazpilot
also lowering the compression on our cars does not fix the weakest link in the block (i.e. the rods). So wether you run the boost to 450rwhp or lower the compression for more boost. I would still not go much past 450rwhp. You will get the same result. 450rwhp is about as far as you want to go on stock internals, so why spend the extra money. when as people can see were already 450 with the 10.3 compression. My plan is to run new rods and pistons but only lower the compression to 9.5 and run 12 to 15 psi boost. much better and safer. just my .02
Old Apr 7, 2004 | 02:57 PM
spazpilot's Avatar
spazpilot
Thanks,
D'oh!
gut feel mainly and the two reasons posted above
Old Apr 7, 2004 | 10:09 PM
D'oh's Avatar
D'oh
Thanks guys,
Saw the info on squich volume just moments ago. Cool stuff.
-D'oh!
sales@czp
Sep 23, 2019 03:30 PM
