PRofec E-01 External Signal Harness
Old May 17, 2004 | 06:33 AM
ACP's Avatar
ACP
Default PRofec E-01 External Signal Harness
Have a question on the External Signal Harness.
I am going to be using this to read my A/F ratio on my e-01.
Which wires do I tap into to do this ?
How many other sensors can I use for this one harness to display reading on the e-01 ?
Like would I also be able to use it to read fuel pressure as well ?
If so, how ?
Thanks
Old May 17, 2004 | 08:02 AM
etx's Avatar
etx
It has two analog inputs. You can read whatever as long as the signal is linear and you know the conversion. I am reading the AFR from my wideband, I just connected the 5vdc output line to the Analog input 1 on the e-01 and configure the conversion rate. If you have an electronic fuel pressure sender hooked up you should be able to tap into the signal from it and read it on the e-01. As long as it's analog and within range. It also has two pulse type inputs that I am yet to mess with.
Old May 17, 2004 | 08:33 AM
derek_i's Avatar
derek_i
Old May 17, 2004 | 03:01 PM
350Now's Avatar
350Now
ETX, how do I tap the fuel pressure sender. Won't the signal weaken when sending to the gauge and if so will the gauge be less accurate?
derek_i, thanks for the image that helps..
Old May 17, 2004 | 04:03 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What is the different between pulse signal input and analog signal input. I think analog single input is a constant 0-5V of current....such as an AEM Wideband.
I plan on running an EGT probe....will that work with analog input 2?
Old May 18, 2004 | 06:19 AM
ACP's Avatar
ACP
thanks guys
So I would hook up the AEM Wideband to the white wire ?
Is that how you wired yours gg ?
And what is the conversion rate ?
Old May 18, 2004 | 07:40 AM
Sharif@Forged
Forged Performance
Originally posted by ACP
thanks guys
Yup...that is all you need. Connect the wire ouptut wire onthe AEM to the white input wire on the Greddy signal harness.
The conversion rate is listed in your AEM wideband instruction manaul. I dont have it in front of me....if you need it...lemme know, and I'll post it later.
Old May 19, 2004 | 09:14 AM
ACP's Avatar
ACP
thanks!
Anyone know what to look for when picking out a Fuel Pressure Gauge so that it can be tapped in to the e-01 ?
(other then the GReddy 60mm Electronic Warning Gauges that you can use with thier meter cable for direct plug in)
Thanks
Old May 19, 2004 | 09:39 AM
Sharif@Forged
Forged Performance
just make sure it has an axtra signal output wire.
Old May 19, 2004 | 09:50 AM
pimpjuice's Avatar
pimpjuice
ACP
Any electric gauge should work. You just need a signal wire to tap into.
350now:
Voltages in parallel will be the same, so it won't lower signal strength (as long as you tap into the voltage wire and use the same grounding source ie. the chassis).
GQ:
An analog signal is a constant wavelike signal (like a sine wave) where a pulse signal is more like a high/low or on/off signal (like a square wave)
RPM is an example of a pulse signal.
Old May 30, 2004 | 09:57 AM
ACP's Avatar
ACP
What would the Green wire - Analog signal output, be used for ?
Old May 30, 2004 | 12:20 PM
ACP's Avatar
ACP
Going to use this post to ask another e-01 wiring question.
The e-01 wiring harness has 4 wires
red (power)
yellow (for warning light)
black (ground)
brown (RMP signal)
Those with the e-01, what do you have the brown wire connected to ?
I have my wiring harness out of the car, and I am soldering all my connections, just want to double check this one.
Thanks
Old May 30, 2004 | 01:09 PM
Sharif@Forged
Forged Performance
Connnect the brown wire to the RPM signal wire. Since our car doesnt have an RPM signal wire, just tap the brown wire coming out of the Greddy RPM adaptor. That will do the trick!
FYI...dont try to tap that Greddy RPM adaptor more than once...there isnt enough just to support more than one additional tap. When I tapped it again for my turbo timer, I lost all the RPM signals...oops..
Old Jun 1, 2004 | 03:12 AM
ACP's Avatar
ACP
thanks gg
anyone else ?
apex locator
Jul 23, 2021 02:27 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Juztin
Nov 22, 2015 07:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
