vortech v2 SQ jackshaft question
Old Jun 16, 2004 | 05:29 PM
esemes's Avatar
esemes
Default vortech v2 SQ jackshaft question
im talkin about the jackshaft housing/bearing/enclosure......
((see below))
in this part, i am hearing an intermentant 'wurlbling' sound....
when i tighten the belt guide (backside of the bracket) i hear it alot more........
it seems to be irregular that this makes a noise as such....... (oftentimes is very quiet, but other times it is noticabley squawking!)
thoughts on a bad bearing??
and yes, i have the best of bad luck ...Im used to it really
i wonder if
VORTECH will send out another one, so i can see if its bad (will have the dealership review this , and inspect thruout, next week)
-eS
ps- i thought i saw someone post on having a bad bearing in the jackshaft assembly........
Old Jun 16, 2004 | 06:08 PM
booger's Avatar
booger
Default pulley
I dont have any noise...that I notice .If you take it off in the next couple days...let me know will you ? I'm putting on a 9lb jackshaft pulley next week and want to know what it takes to get it off . If you need a puller to take it off ? or if it comes off easy ? Is it wobbling on you that you notice ?
Old Jun 16, 2004 | 06:13 PM
dfw350z's Avatar
dfw350z
Default Re: vortech v2 SQ jackshaft question
Now that you mention it mine just started making noise (last two days), I will have my dealer review as well and report back.
Old Jun 16, 2004 | 06:17 PM
esemes's Avatar
esemes
Default Re: Re: vortech v2 SQ jackshaft question
please do!!
and BOOG-- i will see what happens next week!
the belts run straight as an arrow (with little/NO belt dust)........
just a 'warlble' every few rpm's or so.....
but its getting louder
i think
Old Jun 16, 2004 | 06:53 PM
phunk's Avatar
phunk
CJ Motorsports
we installed one for a customer and it makes the same sounds around there.
Old Jun 16, 2004 | 06:58 PM
esemes's Avatar
esemes
same sounds????
dang-
mine has just started the warble/wurble sound, and i can get it quiet by changing the pressure on the belt tensioner.....
if i push down on the guide/tensioner, the thing screams... if i put little/no pressure, the thing warbles.....
i cant seem to find any middle ground, which is unlike before (consideration of the belt stretching too)
Old Jun 16, 2004 | 07:26 PM
dfw350z's Avatar
dfw350z
I guess I got lucky for now, I just went out and tightened the tension on the belt and my noise got quieter. The SC belt was looser than my regular serpentine belt. Time will tell.
Old Jun 17, 2004 | 09:46 AM
esemes's Avatar
esemes
problem solved.....
changed the belt tension (gog belt) and was able to get the alignement/tension correct, so as to keep her quieted !!)
success
Old Jun 17, 2004 | 10:16 AM
mcduck's Avatar
mcduck
esemes...
I've had this same problem two times now. On both occasions it made the wurbly noise for a couple hundred miles (no more than a single tank of gas) then went away.
Had my mechanic take a close look at it and our best guess is that something may have gotten into the bearings, a small piece of debris or something, and that after a while it just gets crushed... hence the noise going away. This is only a guess, though. So far, I have seen no detrimental effects from either occurence (other than the annoying short-term noise).
Old Jun 17, 2004 | 10:41 AM
esemes's Avatar
esemes
Originally posted by mcduck
esemes...
THANKS for the info.......
i thought i might be going crazy....lol (crazier , i guess)
guess i can clean it when i swap out the front pulley next week.....
Old Jun 18, 2004 | 11:37 AM
mcduck's Avatar
mcduck
Let me know if you find some sort of debris or if the noise just goes away... like I said, for us it's just a theory but it seems to fit. It would be good if someone else has the same experience so I can stop what little bit of worrying I've done over it.
kevinapex
Jul 29, 2005 06:26 AM
350zOnJuice
Jul 27, 2005 10:51 AM
ryan350z
Jan 31, 2005 11:33 AM
CaneZMD
Jan 6, 2005 02:54 PM
ELL.21
Australia/New Zealand
32
Oct 13, 2004 09:14 PM
