why not make make your own TT setup ?
Old Jun 26, 2004 | 09:41 AM
LBSOHK's Avatar
LBSOHK
Default why not make make your own TT setup ?
Thats what my boy ( auto mechanic ) asked me when he saw me looking at different TT kits...
hmm I dont know much about turbo's in general , so naturally Im more than a little skeptical about this...
why would anyone buy $6K Twin Turbo setup if it was much cheaper to make one ? obviously its not an east thing to do...
My boy is all pumped up and says he could do the job , if we can find the parts ( or have them made )..
so what should I worry about if I decide to go with this project ( most likely during winter time )...
Should I even consider something like that ?
Thanks
Art..
If anyone can estimate cost of this project I would really appreciate it ...
P.S. I dont mind spending few weeks in my garage...
Old Jun 26, 2004 | 10:29 AM
ares's Avatar
ares
Veteran
its not impossible. it is expensive. 60-80$ an hour in labor, and it can take a while to lay out all those parts, then you have waste for broken stuff. you might come out even, but will your setup be as neat and tidy as one that has been tried and tested for maximum efficiency.
if your wanting more power, then it can become cheaper, as theres no replaceing turbos or anything, you get what you want to start with. itll be more expensive than 6000$, but itll be cheaper than 6000$+replacement parts and labor.
Old Jun 26, 2004 | 12:14 PM
350xfire's Avatar
350xfire
Heck, just for 2 turbos and a decent intercooler, you are probably looking at about $3k (I'm almost certain more). So by the time you spend your time and pay people to fab up stuff, you might as well pay the $6k.
Old Jun 26, 2004 | 12:30 PM
LBSOHK's Avatar
LBSOHK
I wont be paying for the labor since my buddy says he can do the job + I got few guys that already went that way ( pushing 450 + rwhp in golf and passat ) so I'll get help from them , Im just trying to find out what you guys think about this...
"Heck, just for 2 turbos and a decent intercooler, you are probably looking at about $3k"
where did you get that info from ? Im not planning to buy huge turbo's ... I think if I bought 2 eclipse turbo's that would be enough power for now...
Old Jun 26, 2004 | 02:21 PM
xswl0931's Avatar
xswl0931
If your buddies provide the labor and know-how, I would say go for it. Besides saving a few bucks (which may or may not be a deciding factor), a custom kit certainly gives you a sense of exclusivtivity. The only downside would be any type of warranty.
Old Jun 26, 2004 | 03:45 PM
LBSOHK's Avatar
LBSOHK
anyone done this ? come on guys I need more input..
Old Jun 26, 2004 | 04:02 PM
LBSOHK's Avatar
LBSOHK
anyone knows if I could buy Greddy turbo headers only ?
Old Jun 26, 2004 | 04:03 PM
ares's Avatar
ares
Veteran
go for it, let us know how it turns out. most people dont have the know-how, tools, or time to do such a thing. of course when your custom building everything it might be a week or more to install, and for some of us, this is our daily driver, so installs need to be somewhat quick, and need to work the first time as well.
Old Jun 26, 2004 | 05:06 PM
S12 driver's Avatar
S12 driver
You will probably need custom fabbed turbo headers. But you can use the 2 14B turbos, get an IC and pipings from eBay, send you ecu to Technosquare and get the 380cc injectors, then you have your own custom TT.
Old Jun 26, 2004 | 05:09 PM
LBSOHK's Avatar
LBSOHK
what approx. rwhp should I expect from a setup like that and costs ?
and also how much custom fabbed turbo headers would cost me ?
thanks
Old Jun 26, 2004 | 07:43 PM
LBSOHK's Avatar
LBSOHK
Garrett T04B15 turbochargers. what about those ?
I found them for $ 500 brand new on ebay...
"Garrett T04B15 turbochargers. Part number 409250-5002. The compressor wheel is a 47mm S Trim. The turbine wheel is a P trim. Exhaust housing is a 1.00 A/R with a T3 flange. The compressor housing is a .60 A/R. Each unit is oil cooled with oil inlet fitting installed. Both units come with exhaust flange gaskets and oil inlet & oil outlet gaskets. "
Old Jun 26, 2004 | 09:16 PM
eskimo's Avatar
eskimo
i'd be a little skeptical getting help from anyone claiming any rear wheel horse power in front wheel drive cars.
Old Jun 26, 2004 | 09:38 PM
MY350Z.COM's Avatar
A custom setup will cost you a lot more. I know 1 person with a custom TT on his 350Z and he regrets it. He could have just bought a PE or Greddy kit for a lot less.
Old Jun 26, 2004 | 09:53 PM
AParshall04's Avatar
AParshall04
Skidazze runs the custom set up, and if i remember correctly it ended up costing him a lot more than a greddy or PE kit. You should talk to him about it.
Old Jun 26, 2004 | 10:40 PM
350ed's Avatar
350ed
Professional
He probably didn't have free labor though right?
Old Jun 27, 2004 | 04:45 AM
LBSOHK's Avatar
LBSOHK
sorry , obviously that was my retarded mistake
and their not claiming it , guy with the golf just hit 10.8 in 1/4 with additional 150 shot
from what I see , people pay mostly for the labor , in my case I wont have to do this and dont see how parts would even come close to $6K...
AParshall04 - thx
I'll PM Skidazzle see if he has a minute to answer few questions , but I thought he was running Greddy TT in his Z..
Old Jun 27, 2004 | 08:55 AM
PoWeRtRiP's Avatar
PoWeRtRiP
its not terribly hard to make a tt setup the problem is getting a turbo manifold which is now available separate from boostlogic. then turbos are relatively cheap, youll need an ic, some means of upgrading fuel, new intake, ecu management, and lots of custom bend piping, +install
manifolds ~1000-1200
turboes (new) ~1000-1500
ic ~1000
injectors ~400
ic piping custom bent ~200-300
emanage/reflash ~500-600
intakes ~200
install ~2000
dyno time (if dont get reflash) ~400
cheapest estimate comes out to 4400 w/o install,
greddy tt w/ ic is only 5600 do you really want to piece together all the parts to save ~1000? its not all that easy to make all the measurements and modifications to make one work that would be less capable than the greddy package
my .02
Old Jun 27, 2004 | 09:34 AM
LBSOHK's Avatar
LBSOHK
PoWeRtRiP thx for the info on headers...
here's my list:
HKS Intercooler for about $300 ( ebay )
2 X Garrett T04B15 turbochargers $ 500 ( ebay )
reflash $600
Intakes $ 100
IC piping $ 200
so far $ 1700 + headers ( $ 1200 ? ) = $2900..
saving of $2700 versus the Greddy Kit...
I was wondering if the block of a 300zx is the same casting as 350z ?
Old Jun 27, 2004 | 09:53 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Not even close. The VG series is completely different.
It wouldn't be worth it anyway. The VQ block itself is very strong.
Old Jun 27, 2004 | 09:59 AM
PoWeRtRiP's Avatar
PoWeRtRiP
here's my list:
reflash $600
Intakes $ 100
IC piping $ 200
dont forget injectors (400)
and i forgot to add downpipes to my list (200-400)
also you may want to double check the measurements on that hks intercooler to make sure it will fit and that it can make decent power. not all ics are created equal.
