Broke #5 connecting rod w/tt @6.6lbs.
Old Jul 7, 2004 | 01:28 PM
  #81
VR3's Avatar
VR3
Charles (phunk) is working on tuning his HKS Fcon with his GreddyTT. Hopefully he'll have something for us this week. Here's some links about it -> link1 and link2
Old Jul 7, 2004 | 01:41 PM
  #82
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Unless something has changed, Tadashi cant reflash with the 440cc injectors. One person has had a good experience reflashing to the 380cc sized injector map, and then doing the fine tuning with the eManage. This would solve the timing issue completely, and then you could enhance the idling, cruising, and starting richness that might develop, by using the eManage to scale the injectors from 380-440 instead of scaling from stock 280-440cc.
At the end of the day, I think you'd still need the eManage, even if you use the TS Reflash on the Greddy kit....due to the 440cc injectors.
But yes, a full stand-alone would be ideal, especially once the boost is raised beyond 10psi. I will say that your tuner is just stating his own exeperience and opinions in tuning the eManage...probably on other cars. The eManage is not difficult to tune especially for a skilled tuner (which I am not ) I am a hack, I got it pretty darn close at 9psi.....a little less timing retard and I will be well above 400whp on a good dyno.
Good luck!
Hth,
Sharif
Old Jul 23, 2004 | 05:59 PM
  #83
joenismo's Avatar
joenismo
I thought I would post a couple more pics. Piston shows some very small signs of detonation, maybe a combination of a weak rod, too much power, and no adjustment in timing.
Attached Thumbnails Broke #5 connecting rod w/tt @6.6lbs.-mvc-001f.jpg
Old Jul 23, 2004 | 06:01 PM
  #84
joenismo's Avatar
joenismo
another pic
Attached Thumbnails Broke #5 connecting rod w/tt @6.6lbs.-mvc-004f.jpg
Old Jul 23, 2004 | 06:05 PM
  #85
joenismo's Avatar
joenismo
Oh yeah, pistons, crank, bearings, and heads are all fine, just the block is damaged. Of course I am going to get new rods and pistons while I am at it.
  #86
LSs1Power's Avatar
LSs1Power
That does look like a weak rod. Can u take a pic of the piston from the top?
Old Jul 23, 2004 | 06:17 PM
  #87
350Now's Avatar
350Now
dang..the rods just got twisted and broke cleanly off the piston. Please take pics of piston up top a close-up please?
Old Jul 23, 2004 | 06:28 PM
  #88
joenismo's Avatar
joenismo
Here is a pic of the piston.
Attached Thumbnails Broke #5 connecting rod w/tt @6.6lbs.-mvc-005f.jpg
Old Jul 23, 2004 | 06:30 PM
  #89
joenismo's Avatar
joenismo
Here is another, and the scrape marks are from me scraping all the caron build up off.
Attached Thumbnails Broke #5 connecting rod w/tt @6.6lbs.-mvc-007f.jpg
Old Jul 23, 2004 | 06:33 PM
  #90
LSs1Power's Avatar
LSs1Power
It doesnt look like detonation to me.... I think the rod did quit on u. Hopefully with the new block and forged parts u can run alot more boost without having this problem again. Good luck man.
Old Jul 23, 2004 | 06:34 PM
  #91
joenismo's Avatar
joenismo
another, also I meant to spell carbon on my previous post.
Attached Thumbnails Broke #5 connecting rod w/tt @6.6lbs.-mvc-008f.jpg
Old Jul 23, 2004 | 07:14 PM
  #92
m3powerrr's Avatar
m3powerrr
joe, so all your bearings were ok? Do you know where I can get bearings from besides the dealership. the hard part is finding right ones for my rods and crank. some are on back order from the dealership. and also at 6.6, what was your HP readings. I have heard anything over 395, the rods were breaking, regardless of timing or lean issues. I just pulled 410 with ugly A/F readings. I know what I am doing this winter. New rods, pistons, and cams.
Old Jul 23, 2004 | 07:20 PM
  #93
joenismo's Avatar
joenismo
I only put out 365whp, but I did have a very large boost leak at the maf tube. Two of the bolts had backed out. Once I had that fixed it ran much stronger.
Old Jul 23, 2004 | 08:23 PM
  #94
350Now's Avatar
350Now
wow very thick carbon build-up. No detonation, so possibly just a bad rod. Keep us updated as you start your build-up. Have you started looking for forged rods and pistons? You will have a monster on your hand when you finish the build with forged internals.
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
