105 Octane
Old Jul 22, 2004 | 01:51 PM
dfw350z's Avatar
dfw350z
Default 105 Octane
Is it safe for us F1 guys to run 105 Octane in our cars.. A local station here sells it for 7.19 / gallon.
Old Jul 22, 2004 | 02:24 PM
JeffesonM's Avatar
JeffesonM
you wouldn't need to pull as much, if any, timing on 105
Old Jul 22, 2004 | 02:30 PM
LaPuLaPu's Avatar
LaPuLaPu
The way it works is that higher octanes normally equal lower combustion temperatures. Lower temperatures normally equal more efficient running. This may or may not pay off in terms of dollars spent per litre of fuel, but wait, there's more. Especially (but not limited to) in forced induction cars (turbo or supercharged engines), intake temperatue is greatly raised by the compressor. This yields a higher in-cylinder charge temperature. Higher temperatures can alter the point at which the fuel combusts, as at high temperatures you can get premature combustion.
Old Jul 22, 2004 | 03:43 PM
dfw350z's Avatar
dfw350z
Default 105
So I guess the idea is I must have a custom R4 MAP to run the higher octane fuel to avoid “Kaboom”
Old Jul 22, 2004 | 03:49 PM
Juztin's Avatar
Juztin
higher octane allows more of a pillow in regards to the kaboom. The higher the octane, the more resistant the fuel is to normal (ie 91 here in colorado, 93 in cali etc) octane ratings. The mean temperature for combustion goes up higher as the octane rating goes up to make it more resistant.
in other words, youre engine will be a lot safer with your current tune w/ 105 octane, but you could always run more boost (since you have a higher combustion temperature threshold) or put timing back in for more power gains.
Old Jul 22, 2004 | 03:58 PM
dfw350z's Avatar
dfw350z
Default 105
Juztin
So if you are sure about this then could I do the following? ½ tank 93 octane + 105 octane ½ tank = est 100 octane without any mapping changes or A/F problems...
Thanks
Old Jul 23, 2004 | 06:21 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
DWF, is the 105 octane stuff unleaded? Most I've seen in unleaded is 100-102octane. If its unleaded, its totally safe for your car. If it is leaded...then dont use it, becuase the lead will destroy O2 sensors and cats in short order.
You can run higher octanes without mapping changes....it's essentially giving you a greater safety margin against detonation.
Old Jul 23, 2004 | 06:25 AM
Yancy's Avatar
Yancy
I routinely run 100 octane gas, which is at around $3.40 a gallon here. Mainly for the ease of mind.
Old Jul 23, 2004 | 06:38 AM
dfw350z's Avatar
dfw350z
They sell the following:
105 Unleaded
114 Leaded
your choice: $ 7.19 /gallon
Old Jul 23, 2004 | 07:13 AM
t32gzz's Avatar
t32gzz
Where is this in DFW?
Old Jul 23, 2004 | 08:17 AM
dfw350z's Avatar
dfw350z
Keith Craft Motor Sports
1611 North Central Expressway
Plano, Texas 75075
972-578-3550
Old Jul 23, 2004 | 01:22 PM
Sharif@Forged
Forged Performance
$7.19 a gallon is crazy expensive. Just find some 100octane for about $4.00 or less per gallon. Personally, I think anything above 100 octane is kinda overkill...if your goal is just to fend off detonation in the sub 10psi boost range.
Old Jul 23, 2004 | 02:52 PM
dfw350z's Avatar
dfw350z
I have been trying to find a station in my area that sells anything higher than 93. So far I have not had any luck except for the place noted above.
Old Jul 24, 2004 | 09:03 AM
dfw350z's Avatar
dfw350z
Default 105
Well today I put in 10 gallons of 105 Unleaded “Synthetic Fuel” and all I have to say is "holy shi#$" It makes my car scream. Although I wish the price was better all that is available in my area is 93 at about 2.00/g or 105 at 7.19/g. So 75 dollars later my ride is very happy. Perhaps as time goes on I will mix 5 gallons to every other tank just for fun.
Old Jul 24, 2004 | 09:14 AM
Florida350zrt's Avatar
Florida350zrt
Default Octane Boosters
What about Octane Boosters?.
Are ther any octane boosters that we can add that are safe and effective?.
Rich
Old Jul 24, 2004 | 09:26 AM
dfw350z's Avatar
dfw350z
Default Re: Octane Boosters
Rich
From my perspective it’s hard to say. I owned a 2001 Dodge Viper and I ran 104 Outlaw in with every tank of gas for a while and did not notice a difference. Although that was a totally different motor etc.. Nothing I have ever added to my tank has made a car have such a noticeable improvement. It’s just expensive for your everyday driver. Anyone else with experience on this please chime in.
Old Jul 24, 2004 | 02:10 PM
Zcool's Avatar
Zcool
Rich
Commercial octane boosters are a rip off. Get some pure toluene from a paint supply store and add it to your tank. There has been considerable discussion on this subject in previous threads. Run a search on "toluene" and you should be able to find all the info you need.
STL_Z_Seller
Aug 31, 2005 08:47 AM
cbsuper
Aug 21, 2003 08:13 AM
oscarmayer00
Jul 17, 2003 05:26 PM
MySunset350Z
Apr 21, 2003 07:00 AM
chahny
Apr 1, 2003 07:50 AM
