What else is the APS using to run a 11.97?
Old Aug 3, 2004 | 06:52 PM
Jergens's Avatar
Jergens
Default What else is the APS using to run a 11.97?
Hey guys, was curious if anyone knew what APS is using to run that 11.97 quarter mile? I tried searching but the search engine tends to be a little too broad and everything with APS popped up. Did the replace the LSD? Slicks? Clutch/flywheel.
Thanks
~Josh
Old Aug 3, 2004 | 06:59 PM
j's350z's Avatar
j's350z
I am not sure about what tires they used but that was only with exhaust, other than that it is a stock track model.. Stock clutch/ flywheel and stock LSD!!! And that was in the early stages of tuning!! Stay tuned for some awesome times with these APS cars including mine!!.
Jason
Old Aug 3, 2004 | 08:32 PM
zero2prove's Avatar
zero2prove
Other than their TT kit, car was fitted with drag radials. I'm not so certain on what octane gas but I'm assuming its 93 or US equivalent. Oh before I forget, a great driver.
Old Aug 3, 2004 | 08:40 PM
SQUILL's Avatar
SQUILL
Default Re: What else is the APS using to run a 11.97?
Thanks
~Josh
If i remember correctly they ran the car 10 psi with drag radials and 94 octane. send aps a pm.
Ibelieve the exhaust was stock but not sure on that one and i know the clutch was stock and i believe their 350z model has the factory viscous Lsd 99% sure but definitly no modded diff or clutch
Old Aug 3, 2004 | 10:39 PM
Jergens's Avatar
Jergens
Yowza. That is rather impressive. Drags certainly help a lot but still that is an amazing run. If it is at 10 PSI that is quite a bit over what it will run stock though I assume. Anyhow I'm interested in their product and waiting to see what the JWT looks like, but sounds like APS is going to be the way to go.
~Josh
Old Aug 3, 2004 | 10:43 PM
SQUILL's Avatar
SQUILL
~Josh
its the most complete most impressive kit ive ever seen !!!! im not sure if JWT as good as a company as they are could possibly offer something better.
Old Aug 4, 2004 | 03:53 AM
shift_6x's Avatar
shift_6x
from what aps's website says, they ran that dyno and quarter mile run with
aps test pipes,
aps cat back exhaust,
94 octane,
9.2 psi boost!!
i am personally very impressed with this kit, i am pretty sure i will get one.
Old Aug 4, 2004 | 06:58 AM
Durrr's Avatar
Durrr
I've got my mind made up, though I need to save the cashola, someone willing to give me the cash? I'll take you for a ride!
Old Aug 4, 2004 | 10:35 AM
phunk's Avatar
phunk
CJ Motorsports
wow 9.2psi!! i would be affraid for my poor connecting rods!
Old Aug 5, 2004 | 03:17 AM
ZZZ-35's Avatar
ZZZ-35
All you guys buying this kit are in for the ride of your life, I've been luckly enought to drive the APS test car running at 9.2psi with the test pipes plus the APS catback exhaust and yes, it as run at higher pressures on stock internal for short runs to test the fuel system etc, you are right, it as a std diff, gearbox and clutch. This is a quality product no lie, I've seen it first hand and as Peter has said it'll be worth the wait, I'm sold, mine's on order, so for those of you not sure let me tell you this is the real deal you won't be dissappointed, if TT's are your choice this is the kit.
David
Old Aug 5, 2004 | 08:06 AM
shift_6x's Avatar
shift_6x
i am sold too, what i like most is the garrett ball bearing twin turbos, they are long life, they can stand higher pressure on a daily basis, the whole kit has very high quality parts. i have looked at all of them, it is going to be fun to install this and even funner driving it.
Old Aug 5, 2004 | 09:36 PM
spazpilot's Avatar
spazpilot
I am pretty sure that car ran with a different clutch because there is no way a stock clutch can handle that power at the drag strip. been there done that.
Old Aug 6, 2004 | 03:51 AM
Durrr's Avatar
Durrr
it was a stock clutch
Old Aug 6, 2004 | 10:09 PM
ZZZ-35's Avatar
ZZZ-35
Standard clutch, I've driven the car and can vouch for that, it was and still is fitted with a standard clutch, gearbox and diff.
David
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
