467rwhp - 451 torque - smoooooooth
Old Sep 7, 2004 | 04:22 PM
  #41
ChrisMCagle's Avatar
ChrisMCagle
Man! that dyno chart brought tears to my eyes. And really impressive is the "smoothing:0"! Wow!!
Congratulations on your achievement. Now please be a good boy and put in the real motor and then see how far that one can go!
-Chris
Old Sep 8, 2004 | 07:12 AM
  #42
Zoomy_1's Avatar
Zoomy_1
I wanna see the numbers on a built long block. I bet you be killing some serious muscle with it.
Old Sep 8, 2004 | 07:27 AM
  #43
etx's Avatar
etx
It would make since that the stock ecu would freak out with a bogus MAF signal. It's expecting to see a change when it moves the throttle plate. Put it back in and you should be good to go.
Old Sep 8, 2004 | 08:57 AM
  #44
azrael's Avatar
azrael
don't forget to clamp it under 5 Volts, maybe with a 4.7 Zener diode or something. The ECU will definitely freak if it sees the MAF voltage hit the limits.
Old Sep 8, 2004 | 11:08 PM
  #45
ZainT's Avatar
ZainT
Curious about your AAM fuel rails. Did the fit into the original wholes or did you have to drill into the motor? I just finished ordering a new fuel regulator with a fuel return system and braided lines, as well as a brembo big brake kit. was wondering if I should go ahead and get the new fuel rails.
Also, great job with the numbers. You curve is almost identical to mine. So smooth and linear. When I get the picture of it, I will post it up.
Old Sep 8, 2004 | 11:14 PM
  #46
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
MORE VIDS PLEASE!!!!!!!!Im hooked
Old Sep 9, 2004 | 02:27 PM
  #47
350z_taquito's Avatar
350z_taquito
what octane gas was used for this dyno session?
Old Sep 9, 2004 | 05:38 PM
  #48
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
i think he said earlier in the thread that it was 100 octane fuel
Old Sep 9, 2004 | 10:56 PM
  #49
350Now's Avatar
350Now
Yup posted on another thread this dyno was done on a 100 octane and Charles is working on tuning with 93 octane.
EnjukuRacing
Sep 30, 2015 06:55 AM
RWDBajan
Sep 17, 2015 04:52 PM
raceboy
Jan 15, 2003 10:18 PM
vicmar90
Dec 2, 2002 01:22 PM
atcga
Nov 10, 2002 10:45 AM
