timing retard- how necessary?
Old Oct 31, 2004 | 11:40 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default timing retard- how necessary?
running 6lbs, how necessary is it to retard the timing at higher rpm's? i just dont feel 100% right with the greddy timing harness and the diodes setup... and the fear of burning out the coils if the ignition is switched on...
should i do it anyway and stop worrying, or is it a non-issue at 6lbs???
any update as to when greddy will come out with a tested and safer method to retard timing?
THX
Old Nov 1, 2004 | 10:12 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It is perfectly safe....at least for the 10 plus people on this board that are using the diodes setup. As long as you NEVER leave the car in the "on" position but engine not running. I've had mine for 6 months and about 7000 miles...no problems.
On CA gas, I honestly think its an absolute requirment...even at stock boost. On 93 octane fuel, its optional in my mind...at stock boost.
Old Nov 1, 2004 | 01:39 PM
braceman's Avatar
braceman
I am using the Greddy ignition harness with the diodes as suggested here in the forum for more than 3 months.
I never experienced any problems with the diodes as I take all the precautions- never leave key in the on position for a long period of time, car really feels great!
I used to run my Greddy TT set up at 6.5 psi without ignition retard, the motor was detonating at high Rpm's and as result the tip of a spark plug broke and one of my exhaust valves was hitten by that- at cyl Nr 3 if I remember correctly.
Now I run my car at 7.2 psi and with timing retard it never detonates, not even at track.
Kostas
Old Nov 1, 2004 | 06:27 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
thanks for the imput everyone...what does a tuner need to know to do this install (i've read the other posts talking about the ignition timing harness install)...anything to add to this???
how many hours labor should i expect???
i have the harness, i have the diodes..
how to tune the timing retard???
THX
Old Nov 1, 2004 | 06:46 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
I have the diodes and the timing harness is in but I get no RPM signal! Is it because of the harness or what?
Old Nov 3, 2004 | 05:57 PM
accordfreak's Avatar
accordfreak
boost on a high compression motor with no timing pulled =BOOM!
general rule of thumb is 1 degree per psi!
Old Nov 3, 2004 | 07:54 PM
gspot35's Avatar
gspot35
I've heard 1 degree per psi over 3psi. So at 6psi, pull 3 degrees on 93 octane.
Old Nov 3, 2004 | 08:16 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
gspot35:
what is your method of timing retard?? greddy harness? diodes?
thanks
Old Nov 3, 2004 | 08:22 PM
gspot35's Avatar
gspot35
Originally posted by 350zDCalb
gspot35:
thanks
I have a Vortech s/c....I thought the thread was how much timing to retard?
Old Nov 4, 2004 | 07:21 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
the thread was my attempt to figure out how necessary retarding my timing is running 6lbs of boost... i plan on getting to it soon, just wondering if i did it in 3-4 months if that would be such a bad thing going w/out it for awhile...
Old Nov 5, 2004 | 04:33 AM
gspot35's Avatar
gspot35
I would suggest it, atleast a couple of degress especially if you are running 91 octane. You should setup your timing also with a retard wall for anything above 6psi, say 10 degrees, incase you get a boost spike. Several guys have broken stuff at the hp, tq, and psi you are running.
Old Nov 5, 2004 | 01:30 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I have the Procharger and mine was done via an ECU reflash. I am running 9 psi and I have 5 degrees of timing pulled.
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
