Coilover Install Question...
Old Jan 22, 2005 | 06:43 PM
DSport G35's Avatar
DSport G35
Default Coilover Install Question...
Hey guys,
Real quick...What interior pieces need to be removed to gain access to the rear shock towers?
Thanks
Old Jan 23, 2005 | 09:22 AM
g6mt's Avatar
g6mt
i think the shock needs to be removed.
Old Jan 24, 2005 | 03:20 PM
HIg35's Avatar
HIg35
NONE, ALL YOU GOTTA REMOVE IS YOUR REAR TIRE AND THEN IT SHOULD BE SELF EXPLANITORY, I FOUND OUT THE HARD WAY.
Old Jan 27, 2005 | 07:39 PM
thebigsadler's Avatar
thebigsadler
to install you don't have to go inside the trunk at all.. 2 nuts inside the wheel well to remove the shock.
to change the settings atop the shock for dampening (if you have such adjustments), you will have to take all of the panelling out in the trunk; and it's not a fun game to play.
Old Jan 27, 2005 | 08:04 PM
g6mt's Avatar
g6mt
to adjust the dampering on my teins (rear) we had to remove the shock. is there an easier and faster way to adjust it?
Old Jan 27, 2005 | 08:18 PM
Jung918's Avatar
Jung918
EDFC
Old Jan 30, 2005 | 12:09 AM
RashMan14's Avatar
RashMan14
man, i have the JIC's, the tough part about adjusting the dampening is not being able to get to if from the inside of the trunk.
That pisses me off like crazy. You have to take the shock out if you wanna adjust them.
Old Jan 31, 2005 | 03:14 PM
djricepik's Avatar
djricepik
I have the HKS Hipermax LS+ and there is a **** on the side that you can adjust the dampening with... SOooooo Nice...
