Drilling intercooler vents in stock G35c bumper?
Old Mar 1, 2005 | 01:27 PM
gersteinp's Avatar
gersteinp
Default Drilling intercooler vents in stock G35c bumper?
The stock G35 coupe bumper is solid in the lower valance in front of where my Vortech intercooler is located. I can't see how any decent airflow will get to it. I don't want to change out the bumper. Has anyone drilled out vents in this area or are there any kits to do this neatly and with small protective grills?
Old Mar 1, 2005 | 01:33 PM
GZire's Avatar
GZire
I haven't heard of any yet gerstinp. Would you have a pic of the intercooler location so it might be easier for others to come up with a solution?
Old Mar 1, 2005 | 01:42 PM
gersteinp's Avatar
gersteinp
A pic would only show the solid area below the front license plate--that's the area I'm thinking of drilling.
Old Mar 1, 2005 | 01:57 PM
bwzabodyn's Avatar
bwzabodyn
nope - everyone is just going with one of the front bumpers out there that replace the factory piece with a different design that utilizes a large center opening for the intercooler (ie GReddy)
Old Mar 1, 2005 | 02:35 PM
G352NV's Avatar
G352NV
I went with greddy.
Old Mar 1, 2005 | 03:33 PM
gersteinp's Avatar
gersteinp
It seems like two discrete holes (about 2 1/2 " diam each) would improve ventilation without too much effect on the lines being very low down on the bumper, under the plate. I wonder if they make some kind of pop-in, grilled vents.
Old Mar 1, 2005 | 04:13 PM
GZire's Avatar
GZire
Sounds like a custom job unless you go with an aftermarket piece like the others have done.
Maybe contact a body shop and see what kind of a quote they can give you for this work. I think it's the best way to make it look nice and since there will probably be some painting, it might be easier for one shop to do everything.
Good luck on it.
Old Mar 2, 2005 | 01:18 PM
huducks's Avatar
huducks
Good luck on it.
two g's i know cut out two regtangular sections where the license plate bracket normally is. both of them have the vortech but later upgraded to top secret and greddy. check the link i have "random nissan pics" theres a shot of the BS g with the cut out.
Old Mar 2, 2005 | 01:20 PM
huducks's Avatar
huducks
we used a dremmel then sanded it down and finished off the edges w/vacuum tubing.
Old Mar 2, 2005 | 02:52 PM
gersteinp's Avatar
gersteinp
How did you make the cut out precisely? I assume the dremel was to smooth out the inner edges. I don't see an obvious picture of the rectangular cutout in your link.
Thanks!
Old Mar 2, 2005 | 03:56 PM
narkotic's Avatar
narkotic
Please don't do this to your G. The two vents on the side are more than enough to supply air flow to this intercooler.
Old Mar 2, 2005 | 07:24 PM
GZire's Avatar
GZire
Thanks!
I'm missing the pics of the G too. The only BS G I see doesn't have a stock bumper.
Those are some great looking cars there huducks.
Old Mar 3, 2005 | 03:32 AM
huducks's Avatar
huducks
on the link check the second picture, the BS g in the middle is the one w/the cut out kinda hard to see. but if u have ne photo editing software u can zoom in on it.
thanks GZire, i'll try on post more pics up later.
Old Mar 3, 2005 | 03:39 AM
huducks's Avatar
huducks
Thanks!
the car origninally had the two holes for the license plate bracket so we just started from there. basically widened the holes a little more w/a small drill bit. surprisingly the bumper is pretty easy to cut into it took us about 20 mins for the whole thing w/o removing the bumper. but than again they ended up changing the bumper.
Old Mar 3, 2005 | 05:21 AM
gersteinp's Avatar
gersteinp
I presume you mean the lower holes. It looks in the picture like the license plate was raised higher about about 2 inches. Did you use a template for the cutout or did you just eyeball it by hand? The rectangular opening, if I'm seeing it right, is exactly what I was thinking--discrete but functional.
Old Mar 3, 2005 | 07:51 AM
huducks's Avatar
huducks
done by hand and it served its purpose for the time he had the bumper on. it didnt look too bad b/c it was different but everyone will have an opinion.
Old Mar 3, 2005 | 11:34 AM
booger's Avatar
booger
Thanks!
I am one of the ones that has cut open the bumper . It cuts like butter [ really ] I made templet of 2 openings right where the L plate goes . PM me your email and I'll send you a older pic of it . I got it on my desk top puter
Justin100
Nov 25, 2021 06:26 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
