2007 G35 question
Old Jun 30, 2007 | 12:39 PM
evolved326's Avatar
evolved326
Default 2007 G35 question
Hey guys my father jsut got a 2007 G35. I did a search but could not find an answer.
On the freeway, is it normal for it to cruise at 70mph @3k RPMs? He has the basic automatic transmission.
Thanks in advanced!
Old Jun 30, 2007 | 12:43 PM
SpeedyG35's Avatar
SpeedyG35
ermmm.....
Old Jun 30, 2007 | 12:52 PM
evolved326's Avatar
evolved326
Not sure if I asked a stupid question from that comment. But, he is used to his TL which cruises at 2k rpm @ 70mph. Legit question if you ask me.
Old Jun 30, 2007 | 09:26 PM
evolved326's Avatar
evolved326
um, thanks.
Old Jul 2, 2007 | 08:47 AM
evolved326's Avatar
evolved326
Wow, no one here has an automatic 2007 G35?
Old Jul 2, 2007 | 08:53 AM
SpeedyG35's Avatar
SpeedyG35
yes its ok to cruise at this rpm levels.... its safe
Old Jul 2, 2007 | 11:31 AM
evolved326's Avatar
evolved326
wow. are all G35 guys smart asses?
Pretty legit question if you ask me. Rpm seems kinda high @ that speeds thats all.
Old Jul 2, 2007 | 11:57 AM
SpeedyG35's Avatar
SpeedyG35
bump for u
maybe some other a$$ would answer u
Old Jul 2, 2007 | 11:59 AM
Lawy'dU's Avatar
Lawy'dU
yeah, a lot of them are. the cruising rpm is fine at 3k. That's completely perfect for a MT car, so I would think it's fine. I've actually never stared at what my idle while at 70 mph is. I'm usually just gunning it so my revs are all over the place.
Old Jul 2, 2007 | 12:50 PM
skaterbasist's Avatar
skaterbasist
The G35 guys are @ G35driver.com
Not sure why you're asking such a question here. G35driver.com has a forum specifically for the 07 G35 Sedan, which would have answered your question within minutes.
Check it out.
Old Jul 2, 2007 | 01:54 PM
evolved326's Avatar
evolved326
Check it out.
Thanks for the replies guys. I thought since I was a member here and there is a g35 section here that I would ask so I wouldnt have to register at g35driver. But Ill just register.
Old Jul 3, 2007 | 12:51 PM
Triji's Avatar
Triji
OK I have an 04 auto coupe and just checked out for you yesterday... at 82 mph I am at 3000 rpms.... at 70 mph I am at 2400 - 2500 rpms... 3K at 70 sounds a bit high to me. what a drain on gas... Go test drive some other 07's and see what they are doing...
I thought my rpms were high at 82 w 3K which is my cruising speed.
Hope this helped a tad / good luck.
Old Jul 4, 2007 | 05:06 PM
Bocatrip's Avatar
Bocatrip
Yes, it's quite normal. There were a few posts on the same subject on other forums. This engine likes to rev in the higher range and also tends to be quite thirsty. It's a very legitimate question.
Old Jul 5, 2007 | 03:08 PM
G35Drvr03's Avatar
G35Drvr03
yeah on my 07 G its around 3k at 72mph....the RPMs are high but i still get good gas milage on the freeway.... .... The RPMs are even higher in Drive Sport Mode.......
Pleask
Dec 21, 2021 03:17 PM
Mattg350z
Oct 2, 2015 06:51 AM
Alexreyes
Sep 30, 2015 11:30 PM
samansharif
Sep 25, 2015 12:31 PM
