Stillen Engine Damper Rev
So since the weather was nice this weekend here in Boston I deceided to install my Stillen engine damper. The instructions where quite clear but the diagrams were a real PITA. The tools that you will need when installing the damper are are a 1/2 rachet with an extra long extension, 10mm, 12mm socket, a 14mm socket and, a flat head screw driver. The install time took me about an hour. The most difficult part in doing this mod was tightening the screw on the non-adjustable end of the damper that sits on the frame rail of the car. After the install I must say that the difference is highly noticeable! I can only speak on behalf of the 6MT owners. I felt an increase in torque and the power and best of all no vibration anywhere. This little mod is worth every $85.00 and then some
. Prior to the install I notice that the engine would vibrate a lot so I did some research on the product and decided to give it a try. I'll take some better shots later on after degreasing my motor (as you can see I got some grease on the damper after lubing the holes for the bolts
Does this mount at a different spot on the G than the Z cause I could have swore I've seen them mounted from the strut tower on Z's and this doesn't appear to be even close to that.
Yeah I can give you a hand. Just PM me here or on Driver (whenever it gets back up)
Originally Posted by xjonmo
hmm i was looking into this..wanna help me install if i get it?
I have both Stillen products, great low cost mods with a performance difference.
liqalu04
Jan 2, 2022 12:58 PM
