G35 supercharger problem
Old May 16, 2023 | 07:48 PM
Joey0909's Avatar
Joey0909
Default G35 supercharger problem
Hey guys need some help with my g35 coupe. Have a Vortech v3 supercharger on my car. 1200 injectors, 450 fuel pump . Issue I’m having is that under load (in gear) after about 4-5k rpm car stutters and doesn’t want to go past it. Another thing is if I rev the car over 3-4k on neutral or even on gear as soon as I let go off gas car goes under 500 rpm’s and occasionally will stall. Checked for vacuum leaks with smoke test no leaks at all. Checked for exhaust leaks no leaks. No CEL lights on. Any suggestions, thank you
Old May 17, 2023 | 05:01 AM
iideadeyeii's Avatar
iideadeyeii
Those injectors are huge. What's your AFR at the times where you are having issues?
Old May 17, 2023 | 05:57 AM
i8acobra's Avatar
i8acobra
Gonna need more info. What are you using to tune the car, UpRev? Stand alone? Sounds like either too much fuel or not enough fuel. What plugs are you using, and what's the gap? Is that 450 pump running off the stock wiring or did you run a 10ga wire and a new relay?
Old May 17, 2023 | 01:05 PM
Joey0909's Avatar
Joey0909
yes I’m running a relay kit with thicker wiring. And I’m on a conservative tune right now with uprev. I’m using the 2 step colder spark plugs along with the z1 high energy coil packs. Everything is fine with those.
Old May 17, 2023 | 01:08 PM
Joey0909's Avatar
Joey0909
I have not checked that yet but af gauges normally sits around 13-17. I know I don’t have a exhaust or vacuum leak since I already did a smoke test and it’s all good.
Old May 17, 2023 | 01:12 PM
Joey0909's Avatar
Joey0909
I do want to add that with my logs I notice that ignition timing can go from 15 to as high as 40 and even as low as -5 depending if I’m on idle stepping on it or when I let go off gas. I am still not pushing boost. So this issues gots me stuck
Old May 18, 2023 | 05:13 AM
iideadeyeii
13-17 is very lean under boost! Get a new tune. You're going to ruin that motor
Old May 18, 2023 | 06:24 AM
i8acobra's Avatar
i8acobra
At idle, or load? Should be 11.5 to 11.7 under load WOT.
Old May 18, 2023 | 08:42 AM
bealljk's Avatar
bealljk
What mass airflow sensor are you using?
I wonder if youre exceeding the limits of the OEM MAF w/o a resistor or aftermarket / rescaled MAF.
13:1 is fine for low load and low RPMs, 17:1 is fine for idle
10:1 to 12:1 for boost
Old May 18, 2023 | 11:35 AM
Joey0909's Avatar
Joey0909
I’m not running boost yet. I’m on a conservative tune still. Trying to get the car right before hitting boost
Old May 18, 2023 | 11:36 AM
Joey0909's Avatar
Joey0909
13-17 on idle
Joey0909's Avatar
Joey0909
sorry forgot to add that on my original post. I don’t have the OEM one , I’m running the uprev maf sensor
Old May 19, 2023 | 09:38 AM
bealljk's Avatar
bealljk
Is it safe to assume that you’ve rescaled yoru MAF sensor accordingly?
What have you done in the tune to get the car started and up & running?
Old May 19, 2023 | 12:33 PM
Joey0909's Avatar
Joey0909
I just got it flashed to get running , everything is relearned.
Old May 19, 2023 | 01:36 PM
bealljk's Avatar
bealljk
Did you modify your K-Value (I believe) for the Uprev MAF Sensor?
Unbootable
Jun 26, 2018 03:28 PM
jdm3fiddyZ
Oct 9, 2004 08:25 AM
2003G35
May 6, 2004 07:55 AM
Anishd
Dec 6, 2003 09:01 PM
JonsilvZ
Feb 17, 2003 12:37 PM
