Kinetix plenum?
Old Jan 5, 2005 | 02:38 PM
PumpedVA's Avatar
PumpedVA
Default Kinetix plenum?
when I get my plenum installed can I still use my OEM engine cover?
Old Jan 5, 2005 | 02:51 PM
zachcrosen's Avatar
zachcrosen
Yes, you just need to use the spacers that come with the plenum.
Old Jan 5, 2005 | 03:22 PM
PumpedVA's Avatar
PumpedVA
thanks bro
Old Jan 5, 2005 | 05:59 PM
jlimquest's Avatar
jlimquest
Default Kinetix Plenum
You may also need to adjust the strut bar to avoid any vibration & rubbing. The spacers I used were 1/2 the thickness of what came w/ the V4 plenum. Use 2 clay ***** on top of the highest point of the plenum & cover. Close the hood to test if you have enough clearance.
Old Jan 6, 2005 | 03:01 AM
ttsupra94's Avatar
ttsupra94
I didn't put my engine cover back on, or the strut bar. I tried using some spacers on the strut bar but it was still pretty close.
Old Jan 7, 2005 | 08:35 PM
daytona350z's Avatar
daytona350z
Default Re: Kinetix Plenum
who painted your plenum??
Old Jan 20, 2005 | 06:11 AM
Billyz 212's Avatar
Billyz 212
Does the Kinetix plenum offer less air in than the crawford? Seeing as the kinetix still clears the strut bar and allows the enigine cover I would think it doesn't reely allow that much more air than the stock plenum. anyone have an answer? By the way jlimquest that engine bay looks gorgeous. It definately looks beeter than the crawford.
Old Jan 20, 2005 | 06:32 AM
Bahraini350Z's Avatar
Bahraini350Z
I attached the cover with the front screws only
Old Jan 20, 2005 | 08:24 AM
jlimquest's Avatar
jlimquest
Default Re: Re: Kinetix Plenum
who painted your plenum?? [/QUOTE]
I sanded, primed & painted the Kinetix plenum w/ Plasticote Engine enamel high-heat paint (500 degrees). Bought them in Pep Boys. The Engine cover was painted by Gundam02.
Old Jan 21, 2005 | 08:24 AM
Billyz 212's Avatar
Billyz 212
Anyone have an answer regarding the airflow of the kinetix plenum versus the crawford?
allmycarsdie
May 13, 2016 04:38 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
