Help with Kinetix V4 install
Old May 2, 2005 | 07:28 PM
vantage350z's Avatar
vantage350z
Default Help with Kinetix V4 install
Just finished up my plenum install. Everything went very smooth until I started the motor up. Iam getting a very bad whistle Very Very loud, almost alarm sounding. anyone have this problem? anyone know how to fix this problem? Hope i didn't damage the motor.
thanks in advance,
Old May 2, 2005 | 07:49 PM
jkoc's Avatar
jkoc
it is a leak.
check for vacuum leaks
check that the rubber cuff around the oil cap didnt sneak in between the plenum sandwich.
checkthe throttlebody bolts..
Old May 2, 2005 | 08:42 PM
StarcraftBW's Avatar
StarcraftBW
check for the M3 metal plate! You may need to cut a small part of the M3 plate off.
Old May 2, 2005 | 09:03 PM
imalazeeass's Avatar
imalazeeass
you shouldn't have to cut the plate for the v4 from kinetix i dont think.. well at least i didn't have to when i had mine
Old May 3, 2005 | 08:34 AM
vantage350z
M3 plate looks good.
Old May 3, 2005 | 06:10 PM
SPRacing's Avatar
SPRacing
Did you use a torque wrench for the install.
Old May 4, 2005 | 08:44 AM
slaponte's Avatar
slaponte
Definetly leak. It would be extremely hard to damage your motor with this kind of mod. At worst, it will just run like crap, or not run at all, so don't stress out.
Making sure you torque it down properly and IN THE RIGHT ORDER would help eliminate the leak. If you didn't torque it right, or in the right order, it is extremely likely it is not on there evenly.
Old May 4, 2005 | 12:25 PM
JimRHIT's Avatar
JimRHIT
Originally Posted by jkoc
it is a leak.
+1
If you are looking at it from the front ... look at the right front side where the oil cap is ... the gasket there tends to get stuck in between the Kinetix and the stock lower.
Jim
zillinois
Feb 14, 2005 02:43 PM
murrman100
Aug 30, 2004 08:49 PM
lorinserbenz
Aug 21, 2004 10:24 AM
FLY BY Z
Mar 1, 2004 02:16 PM
all_bark
Feb 22, 2004 11:11 AM
