Intake Power Gasket
Old May 9, 2005 | 10:37 AM
kopo's Avatar
kopo
Default Intake Power Gasket
I ran into this by accident looking for exhaust gaskets on ebay. Its probably one of those turbonator type mods, but I just wanted to ask the experts for opinions....
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
From link...
These gaskets were engineered to reduce the heat transfer between the Heads and the intake manifold. The result is much cooler/denser intake charge, higher horsepower and greater reliability. You can expect as much as a 5% increase in horsepower with the use of this gasket set. If you prefer, you can stack our gaskets for more performance potential.
The spaceage material used in the gaskets easily handle the extreme heat output of a high performance engine. The gasket also seals on imperfect surfaces, and can be used over and over again. NASA uses this same material in multi-million dollar machinery.
Unlike other brands, this gasket won't dissolve or misshape in gasoline or any other automotive liquid for that matter. As well, it will never rust or oxidize like the factory gaskets, which could keep the manifolds from sealing properly. Our gasket will not warp under heat and exposure to gasoline like the competition. As well, our material has superior thermal properties, which allows us to keep the gasket thinner so changing to longer Intake manifold studs is not necassary.
Old May 9, 2005 | 07:44 PM
ReavTek's Avatar
ReavTek
Seems like a scam. Anything that promises that much for a freaking gasket is bs. As long as you get new gaskets from Nissan when you open up the motor you should be fine.
Old May 10, 2005 | 02:01 PM
sisco534's Avatar
sisco534
+1.....No gasket will cool down the air its like 1 cm thick how would that cool airflow.Lots of scams out there.
Old May 10, 2005 | 02:22 PM
jkoc's Avatar
jkoc
reminds me of the hondata gasket... back in the days when i had a hodna prelude
http://www.hondata.com/heatshield.html
Old May 10, 2005 | 04:34 PM
vfr350's Avatar
vfr350
I have the lower plenum and tb gasket with a coolant bypass. You would be stunned, below the gasket will next to burn your finger, directly above doesn't even come close. I can now rest my had on my Crawford plenum without worrying about it being hot after running around. So it does work. I got mine from http://www.fisherspeed.com/
Old May 10, 2005 | 08:59 PM
Vader007's Avatar
Vader007
Actually back in the day when i was into the 5.0 mustangs, BBK came out with the phenolic resin intake manifold spacer. It promised the same type of performance and was documented by many to do just that. So lets not knock things we dont understand. Who would of thought 1500 HP was possible from a four banger? Why do you think kinetex came out with the plastic plenum?
HHMMMMMMM!
New to the forum.
Vader007
Old May 11, 2005 | 02:14 PM
Road Warrior's Avatar
Road Warrior
how good of quality is this brand.....i bought the ebay gaskets and they are of poor quality. they are unfinished and look like they were cut out on a jigsaw therefore does not exactly represent the stock gasket. i am sending them back and looking for a better quality set.
thanks
Old May 11, 2005 | 02:19 PM
vfr350's Avatar
vfr350
They looked good, I installed them over the stock gaskets with no issues. Edges were smooth, looked good for what it is......
Old May 11, 2005 | 05:39 PM
Road Warrior
i think i am going to order a set...how is their shipping?
i had a similar setup on my acura...hondata claimed 5 hp on their manifold gasket. these really do help to reduce temps a little bit...can't hurt having cooler air coming in and 65 bucks really isn't that bad.
thanks for the link and info
Old May 14, 2005 | 10:38 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Has anyone gotten a response from fisherspeed?
Old May 14, 2005 | 07:11 PM
Road Warrior
i have sent 2 emails recently and have not got a response back yet
Old May 14, 2005 | 09:06 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
same here
Old May 15, 2005 | 03:21 AM
jkoc's Avatar
jkoc
the IM plastic spacer is cheap but it is a damn hassle to install...
Old May 18, 2005 | 08:03 AM
Road Warrior
not really worried about the install...trying to get the damn thing seems harder than installing it!
Old May 18, 2005 | 08:21 AM
jkoc's Avatar
jkoc
lol
Old May 18, 2005 | 09:57 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I have the new kinetix on the way anyways so I'll have everything apart. Just need to get the damn spacer.
Old May 18, 2005 | 10:02 AM
Road Warrior
yep, that would be a great time to install the gasket. i like the fisherspeed gaskets but can't seem to make contact. if anyone knows how to get a hold of these guys please let me know.
i don't really care for the powergasket and i have a set if anyone wants to buy them....never installed...shoot me a pm if your interested
Old May 18, 2005 | 10:15 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Maybe one of the TX's guys will have a phone # since there in Plano.
Old May 18, 2005 | 02:31 PM
vfr350's Avatar
vfr350
I checked my emails from Ethan at fisher speed, but no phone #s were included.
Old May 18, 2005 | 10:06 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I think I found another place that sells a similar thing.
http://www.nipponpower.com/engine/ma...ar_gasket.html
I think you get both the manifold gasket (fisherspeed) and the gaskets you can buy on ebay in a package deal. I'm gonna give them a call in the morn. Anyone ever heard of these guys. It looks like the Nextgear stuff is popular with the VW crowd.
