Intake Plenum
Old Jul 7, 2005 | 10:47 PM
RGarramone's Avatar
RGarramone
Default Intake Plenum
Is it worth getting the crawford plenum seeing that u cant use the stock strut tower bar or the engine cover or should i just go with a kinetix? which is better and gives more hp gains. also can u tell me where i can purchase either of these?
thanks
Old Jul 8, 2005 | 01:32 AM
tonysZ's Avatar
tonysZ
don't get the kinetix, this is my opinion but the thing looks like batmans body armour! Plus I've heard nermous complaints about kinetix and them cracking etc. Get the crawford never herd one complaint, great customer service! www.crawfordz.com
Old Jul 8, 2005 | 05:25 AM
HKS350z's Avatar
HKS350z
I have the Kinetix V4 plenum right now and I have no problems with it. Gave me good gains and loving it. Also, if the plenum was to ever break, crack, melt, etc, they offer a lifetime warranty on it. =)
Old Jul 8, 2005 | 07:55 AM
Road Warrior's Avatar
Road Warrior
i have had the aam spacer and now i have the crawford cast plenum. imo, the crawford gives a little more power.
there are no vacuum leaking issues on the top plenum bolts (6 each) and no hardware issues because of added material thickness that you get with the spacer vs the plenum. the crawford plenum does not add thickness therefore you use the stock hardware.
the crawford strut bar is of great quality and if you want to keep the engine cover you would have to modify it slightly but it would work
as mentioned, the crawford crew is great and these guys know their shiiiat. k
Old Jul 8, 2005 | 09:18 PM
MY350Z.COM's Avatar
More volume, more power.
the Crawford has the most volume.
Old Jul 8, 2005 | 11:30 PM
Fairlady_z33's Avatar
Fairlady_z33
i want to get the crawford v5 polished plenum but i wont be able to use the stock cover with the stock stock strut they say it doesnt clear there plenums extra height what options r out there. Also i want to get their headers too butif im not mistaking they r not normal lenght so i cant use with testpipes or am i wrong.
Old Jul 9, 2005 | 12:29 AM
NissanZfan's Avatar
NissanZfan
How does the pop charger compare to these you guys speak of?
Old Jul 9, 2005 | 06:26 AM
randyshemin@comcast.'s Avatar
The Popcharger is an air filter setup.
The plenum is the "intake manifold" atop the engine.
See links:
Plenum: http://www.crawfordz.com/plenum.htm
Popcharger: http://www.jimwolftechnology.com/customer_results.asp
They are both excellent mods.
Old Jul 9, 2005 | 06:47 AM
lowrider's Avatar
lowrider
Fairlady
You're right the Crawford tubes are not normal length, each tube is 26". However, they are bundled so that the header fits in the same space as an 18" tube header or a normal exhaust manifold. So yes, you can use normal or hi-flow cats or test pipes with them.
For their plenum you can use your stock engine cover if you cut it to fit, and for the strut bar you'll need to use theirs or the stillen.
Lou
Old Jul 9, 2005 | 07:44 AM
Fairlady_z33
hey thanks
Old Jul 9, 2005 | 12:28 PM
Road Warrior
the crawford strut bar looks better than the stillen imo....but those are the only choices if you go with the crawford plenum
Old Jul 29, 2005 | 10:16 PM
Badmonkey's Avatar
Badmonkey
I read somewhere that the APS strut bar would fit with the Crawford plenum. Is this a fact?
Old Jul 30, 2005 | 06:59 AM
ZBoater's Avatar
ZBoater
+1. Kinetix customer service is second to none. Plus, I like the Batman armor look!
Old Jul 30, 2005 | 12:34 PM
ReavTek's Avatar
ReavTek
Kinetix has had it's share of problems but they ALWAYS make sure the customer is happy. I've seen cracking, melting, exploding and Kinetix always offers a replacement free of charge. With their latest revision I have yet to see any major issues so you should be fine. I would wait to see what 350EVO has to offer though before you plunk down your money on any plenum.
Old Jul 30, 2005 | 01:46 PM
Road Warrior
the aps strut bar is nice....give them a call to be sure it will work. it looks similar to the crawford and a bit better imo. i have the crawford and i am very happy with it...plus the great customer service and absolutely no problems to worry about!!
Old Jul 30, 2005 | 02:00 PM
Badmonkey's Avatar
Badmonkey
I currently have the Crawford, but it rubs on my hood.
Old Jul 30, 2005 | 04:54 PM
Road Warrior
thats what those rubber bumpers are for included with the crawford strut bar....similar to the stock bumpers. when placed correctly, no rubbing....at least not in my case. this is the first i have heard about a rubbing issue with the crawford fsb
Old Jul 30, 2005 | 09:32 PM
Badmonkey's Avatar
Badmonkey
I bought it from another member and never got any rubber bumpers. Does anyone have a pic?
Old Jul 31, 2005 | 02:09 AM
Get some 3/4 inch wide self-adhesive black weatherstripping from a hardware store.
Cut 2 pieces about 2 inches long and attach to the hood where the rubbing occurs.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
