Oil Residue in Intake Manifold
Old Jul 13, 2005 | 02:24 PM
Badmonkey's Avatar
Badmonkey
Default Oil Residue in Intake Manifold
I am installing my fuel system and injectors and noticed oil in my intake.
Is this caused by blowby and the PCV system? Will a catch can fix this? Can I vent the catchcan to the atmosphere, or does it HAVE to go to the intake, pre compressor?
Old Jul 13, 2005 | 02:29 PM
Kwame's Avatar
Kwame
Yeah I have the same thing in my car and it is NA. I installed a cusco oil catch can and it has decreased dramatically. I got the catch can from www.z1auto.com.
P.S. Since mine is NA I vented the opposite side to the atmosphere using a breather filter.
Old Jul 13, 2005 | 03:39 PM
booger's Avatar
booger
Possibly a bad seal in the blower also . If it continues after catch can install.....its a very good chance a seal is bad...hope not
Old Jul 13, 2005 | 06:09 PM
POWERSLIDIN's Avatar
POWERSLIDIN
I noticed a little in mine when I installed the Crawford too. Somebody has a thread on here about putting a puke tank on a Procharger set up w/pics. I'll do a search and see if I can find it again for you.
Old Jul 13, 2005 | 06:11 PM
POWERSLIDIN
Here you go Monkey... https://my350z.com/forum/showthread....ocharger+catch...hop that helps. Good luck with the fuel system!
Old Jul 13, 2005 | 08:04 PM
Badmonkey's Avatar
Badmonkey
Thanks for the link. The fuel system is coming along, I got the rails and injectors installed. Now I have to make some custom lines among other things, of course.
Old Jul 13, 2005 | 08:35 PM
POWERSLIDIN
No problem. I found somebody's homepage the other night where they had taken the stock rails and tig'd an fittings onto the end of them and made a return fuel system. They used quality stuff and a good regulator and it looked pretty good. I may look into this. I also talked to friend of mine who has access to cnc and he thinks if we order the fuel rail material he can make me some rails. I appreciate the offer on the fuel rails I'm just trying not to spend a lot more on the car cause I need a bigger shop more than anything. Keep us updated though!
Old Jul 13, 2005 | 08:39 PM
Badmonkey's Avatar
Badmonkey
I ended up getting them from John Isbell, for $265 shipped.
Old Jul 14, 2005 | 05:24 PM
Badmonkey's Avatar
Badmonkey
What can I do to clean this up? Is there something that I can spray on it that is safe for the engine? I will try to wipe up the majority of it, but I can only imagine what my valves look like.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
