Intake Plenums and nitrous????
Old Jul 31, 2005 | 06:42 PM
TIGHT-Z's Avatar
TIGHT-Z
Default Intake Plenums and nitrous????
I have a 75-100 shot of nitrous in my Z, and I was wondering if anyone know if it would be fine to spray with my new Kinetix V4 plenum? For those who dont know, the V4 is made out of a high-durable type of plastic.
Old Jul 31, 2005 | 06:54 PM
raptorbh12's Avatar
raptorbh12
hmm i was wondering the same thing, but i believe it is fine as long as you dont purge into your engine and you have an external purge. I believe that prevents your intakes from blowing up. Someone please correct me if im wrong.
Old Jul 31, 2005 | 09:47 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Sprayed lots of times w/ my V4 no problems @ all
Old Aug 1, 2005 | 07:51 AM
TheBigShow's Avatar
TheBigShow
speakin of purgin, is there any place u could purge that may have a performance benefit (coolin effect)?
Old Aug 1, 2005 | 04:46 PM
Gators2001's Avatar
Gators2001
other then the radiator, maybe the on the oil pan, hmmm... Up that hot stripper's skirt.... (I cant let that thread die).
Old Aug 1, 2005 | 05:54 PM
sentry65's Avatar
sentry65
the burninator
radiator or oil pan i'd think no
you don't want your oil to be too cold - could damage the engine
same with the coolant
Old Aug 1, 2005 | 06:03 PM
Gators2001's Avatar
Gators2001
my post wasnt serious..... it was an old joke.... sorry should have metioned that.
Old Aug 10, 2005 | 11:38 AM
Silkk's Avatar
Silkk
I've seen a friend EXPLODE a Kinetix V4 with a 100shot at the track...
He was running a very safely set-up wet kit with filtered solenoids, NX computer, external purge, etc. and it still went kaboom. He managed a 12.96 on 19" street tires with the kinetix blowing a hundred meters or so from the line.
I would never run nitrous on a plastic manifold no matter how thick and durable of plastic it is.
Old Aug 10, 2005 | 12:35 PM
TheBigShow's Avatar
TheBigShow
i was thinkin of replacin my stock plastic intake tube w/ a cf one. is it hard to get a clean hole drilled through cf?
Old Aug 10, 2005 | 12:50 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Nope, just as easy as plastic.
Old Aug 17, 2005 | 07:11 AM
QuadCam's Avatar
QuadCam
the stock z tube stinks for mounting the nozzle. The plastic is very soft and rubbery.
Old Aug 20, 2005 | 08:41 PM
Gators2001's Avatar
Gators2001
I put mine in the stock tube didnt have a problem.
Old Aug 21, 2005 | 06:35 AM
QuadCam's Avatar
QuadCam
when you tighten down the mounting bung (on an NX kit) the soft stoxck intake tube deforms. It prevents you from tightening it all the way down.
It is not that the tube leaks or anything, but when removing the tube, the mounting bung can move (changing the direction of the spray nozzle)
It is kind of dificult to explain, but a harder tube would be preferable. I have noticed that the stock tube gets harder the furthwer away from the throttle body you get. Most companies recommend hat you mount the nozzle between 2-6" from the TB though,
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
