Motordyne Iso Thermal Plenum Spacers
Old Oct 15, 2005 | 12:12 AM
  #241
BlueDragonZ's Avatar
BlueDragonZ
Man oh man, I already got my order today. Because I'm in HI I was expecting it sometime next week. I can't wait to get it installed tomorrow morning.
Old Oct 16, 2005 | 04:42 PM
  #242
oggie's Avatar
oggie
Tony, I have just install the spacer over the weekend. I now have a deeper exhaust tone and maybe some power gain. The part that I didn't quite understand is why we need to disconnect the -ve lead in the battery? All my memory settings are now gone and I have to re-program them. Please shed some light on the subject. Thanks.
Old Oct 16, 2005 | 05:07 PM
  #243
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
HI Oggie,
Yes, things like the radio station presets will need to be reprogramed, but disconnecting the battery negative is a prudent safety precaution.
When unplugging the TB harness, most of the time it isn't a problem. But sometimes it can cause a check engine light and require a Idle relearn procedure. Having to dig through the service manual and getting the reset procedure right can be a real pain.
Disconnecting the battery negative is a good way to help insure you don't have to go through the idle relearn procedure.
As far as power gain is concerned, even if you don't feel it, its definitly there. About 11-13 HP in the top end. When installed and properly run on a dyno, it shows the same results every time.
Old Oct 16, 2005 | 05:10 PM
  #244
DavesZ#3's Avatar
DavesZ#3
Nissan generally recommends disconnecting the battery when doing any repairs on the car, especially if you're going to be unplugging some of the sensors. If you don't disconnect the battery and unplug the throttle body, you will need to recalibrate the throttle position sensor. That's a lot more trouble than reprogramming the radio.
Old Oct 16, 2005 | 07:40 PM
  #245
oggie's Avatar
oggie
Guy, thanks for the info...now I know.
Old Oct 16, 2005 | 09:06 PM
  #246
Hydrazine's Avatar
Hydrazine
Thanks Dave! LOL You said it a lot better than me and with fewer words!
Old Oct 17, 2005 | 01:37 AM
  #247
BlueDragonZ
Question
Ooops, I guess I missed that part about disconnecting the neg battery. She seems to be running fine without any CEL coming on. I don't really notice any increase in the performance after driving her today. I thought that I would feel something like when I first installed the spacers several months ago.
Old Oct 17, 2005 | 05:04 AM
  #248
350Zenophile's Avatar
350Zenophile
Well, If you've never experienced a loss of power from heatsoak, you will likely not be able to notice a gain from this mod.
Old Oct 17, 2005 | 11:05 AM
  #249
Hydrazine's Avatar
Hydrazine
+1 on the heat soak. Iso Thermal doesn't make power like the spacer does. Not at all. But it will help to minimize the loss as things heat up.
Old Oct 17, 2005 | 11:11 AM
  #250
the7ferret's Avatar
the7ferret
You wont feel the difference at first...
But after about an hour of driving and you gun it at a light to pass the guy next to you you go WOW~!
Old Oct 17, 2005 | 12:22 PM
  #251
BlueDragonZ
Thumbs up
That's cool I completely understand what it does. I guess I was just expecting the same result that I got when I first installed the spacer.
I'll be drivng a lot today so I'll definately get a better feel for it.
Old Oct 18, 2005 | 07:39 PM
  #252
Eldy's Avatar
Eldy
Hey Tony! I was out of town this weekend when those plenum support studs came so I didn't get to install 'em until today! (I got too antsy and installed the gasket 2-3 days after I picked them up, but didn't put the old aluminum support studs back on because the old adhesive had disintegrated and it was a pain to make sure they were on the bolts.) I only drove the car from glendale to pasadena and back anyway...
The new plastic studs that the bolts snap into are great! The thermal gasket and CCV are unbelievable!! I'm waiting for a hotter day to get post-install readings because the pre-install readings were done on 95+ ºF days so I'll get you those deltas hopefully (c'mon sunshine!!!) this week.
Thanks for another awesome product!!
Old Oct 19, 2005 | 08:51 AM
  #253
houseofheil's Avatar
houseofheil
Originally Posted by Eldy
...but didn't put the old aluminum support studs back on because the old adhesive had disintegrated...
...The new plastic studs that the bolts snap into are great!
+1.
I was an early customer with the 3/8" spacer, and I agree that the new plastic studs are much better.
Much better indeed.
When I took off the upper plenum to install the new ISO gasket, I also noticed the adhesive failing. It probably doesn't matter if you don't take the upper plenum off; I'm sure they'll stay in place 'cause the bolts are torqued down. But if you do take off the upper plenum, you'll notice the adhesive. The new design w/o adhesive is great!
Old Oct 22, 2005 | 05:52 AM
  #254
zzz350's Avatar
zzz350
sorry guys, did the GB start yet? I couldn't hang with reading all 13 pages in this thread. Help, in need of more power!
Old Oct 22, 2005 | 06:02 AM
  #255
DavesZ#3's Avatar
DavesZ#3
Actually, it ended about two weeks ago....
https://my350z.com/forum/questionable-posts/144026-motordyne-iso-thermal-plenum-spacer-gb.html
Check the bottom of the first post by Hydrazine. Ends October 8th.
Old Dec 20, 2005 | 07:44 PM
  #256
Z_xtc's Avatar
Z_xtc
It would seem to me that additional gains would come from not heating the TB at all - even on the Polarized Copper TB Heater - (except when it's really cold) since all the air passes right through it and that's just another opportunity for heat soak, is it not?
Or is the amount of heat soak negligible?
(Car is in shop; taking v4 off. Interested in pkg. purchase).
Old Dec 20, 2005 | 08:04 PM
  #257
Hydrazine's Avatar
Hydrazine
There will be some amount of heat transfer but I would say it is negligible relative to a heat soaked upper and lower collector.
The TB housing is essentially a short length of tubing with a very smooth bore, so the heat transfer won't amount to much. The upper and lower collectors OTOH are a very different story. They have much more surface area due to the much larger size, a very complex shape providing much more contact area, and a rough sand cast finish. The air flowing through the runners is also going to be very turbulent because of the nature of the pulsed flow.
So yes, a heated TB will transfer a small amount of heat but its essentially negligible compared to everything else that will no longer be burning hot with air flowing through it.
OTOH, the Copper is a big plus if you are driving in very cold weather. The reason being that unlike the regular Iso Thermal, you are not required to heat the entire plenum when the temperature drops below 55-45 deg F. So it allows you to take advantage of all the cold air you are driving in.
Its also a good trade when you consider the convience factor. Its a total plug and play solution. No switching of valves based on weather conditions.
If you live in So Cal, Hawaii or Florida it never gets cold enough to freeze anything, but just about anywhere else in the country the Copper is generally a better option.
Tony
Old Dec 20, 2005 | 11:02 PM
  #258
Z_xtc's Avatar
Z_xtc
Tony
Thanks, Tony! I had found some of the above info. in previous posts, but that really helped to clarify the fact that it's not just an issue of "one's automatic, one's manual" but rather a fundamental difference in how the two go about their business altogether. And, the whole surface area concept and how it figures in as well which I know you've mentioned previously but probably can't be stressed enough I'm guessing.
I live in AL where 3/4 or more of the time it's about as hot as FL but for a few months between Dec. & April we have some freezing and sub-freezing temp's to contend with where icing could be a problem.
Sounds like if I want to have my heat-soak cake and eat it too, I could do as another post mentioned and use the CCV valve WITH the Copper, so that during the long hot stretch of months of hot weather I could shut off the small amount of heat going to the TB via the Copper for that last extra ounce 'o power, then at the beginning of the few months of cold temp's I could switch the CCV to "on" and let the Copper take over and do it's thing so I won't have to worry about freezing my TB, right?
(Please excuse any redundancies but I have to figure all this out and be clear on it and make a decision by tomorrow!)
Old Dec 21, 2005 | 09:14 AM
  #259
Hydrazine's Avatar
Hydrazine
Sure, that could be done.
Old Mar 24, 2006 | 08:13 AM
  #260
NISMOFO's Avatar
NISMOFO
Bump....thinking about buying one of these.
