test pipes
Old Sep 26, 2005 | 09:43 AM
Amiricanmade's Avatar
Amiricanmade
Default test pipes
what do you guys think of the APS test pipe's and the Helix test pipes?....if i am all motor right now and i put the APS would i lose power?
Old Sep 26, 2005 | 10:16 AM
Fletch69z's Avatar
Fletch69z
Hypothetically no. You'd gain horsepower, but lose some low end torque. I have test pipes on mine and I notice a tiny bit less torque down low but the acceleration and RPM gain is very linear, instead of choppy like it was before.
Old Sep 26, 2005 | 10:57 AM
Why would replacing the catalytic converters with test pipes result in a loss of horsepower?
Old Sep 26, 2005 | 11:36 AM
Fletch69z's Avatar
Fletch69z
Sometimes reduction in restriction can cause the whole system (intake, engine, exhaust) to work less effectively together and that can cause a loss of horsepower. You have to have some restriction or it wouldn't function properly. At least I think so, .
Old Sep 26, 2005 | 08:10 PM
Amiricanmade
couden't have said it better myself. but the APS is designed for turbo/supercharged cars. i was thinking if im not pushing enough power i would lose some back presure.
Old Sep 26, 2005 | 09:52 PM
jondimellow's Avatar
jondimellow
so for a n/a engine, what would the best deal/bang for your buck test pipe be?
Old Sep 27, 2005 | 12:16 AM
jedi-z's Avatar
jedi-z
I just ordered my helix test pipes from Evasive Mortorsports. I paid 166$ and thats with 3day shipping...I also just ordered the skunk2 plenum spacer and got it for 175$ shipped....I let you know how it turns out
Old Sep 27, 2005 | 05:13 AM
002-M-P's Avatar
002-M-P
Read this you may change your mind....(*backpressure is not needed*)
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
Old Sep 28, 2005 | 04:21 AM
DuPontG35's Avatar
DuPontG35
Also if u have an 05 you'll get a CEL with test pipes. I even put the spark plug defoulers on and it came on within a day. Am I missing something to get the CEL to go away. I have the Helix test pipes with one set of defoulers installed.
Old Sep 28, 2005 | 12:44 PM
undrgnd's Avatar
undrgnd
Take that write-up with a grain of salt. For every "factual" article like this, I have seen a couple of others that contradict it. I'm not saying any part or all of it is wrong, however I will not believe anything these days without substantiating evidence. There's just too much misinformation floating around.
Old Sep 28, 2005 | 12:54 PM
undrgnd's Avatar
undrgnd
I stacked two non-foulers on a different car, where the second O2 sensor is used to gage the effectiveness of the cat, just as in the 350Z. I was able to put off the CEL for a while, but eventually, it came in. What code did you throw? If it's the one applicable to the cats, then stacking two of them will definitely reduce the frequency of CELs, and may eliminate them, although I doubt it.
Old Sep 29, 2005 | 02:43 AM
DuPontG35's Avatar
DuPontG35
Not sure what code I didnt run it I had a shop put them on cause they have to be drilled out to 1/2" and the day I needed it done I was dropping the car off to get the rear end fixed. I heard of stackin them but I've kinda given up unless there's an o2 sim cause I've spent money trying to fix it and it comes back and if the stackin method gives me one week as opposed to one day without a CEL than thats not worth it either, but thanks for the info cause I do remember hearin about the stackin thing.
Old Sep 29, 2005 | 08:51 AM
undrgnd's Avatar
undrgnd
Get the code, then figure out what you need to do. Stacking them is really easy because you don't need to drill out the bottom one. It takes only of few minutes to install. You will probably get several hundred miles, or more, or you may never get a CEL; it's just hard to predict. Simulators are a PITA too, especially if you get one that doesn't work or is installed incorrectly.
Old Dec 3, 2005 | 03:33 PM
Amiricanmade
Alright...i installed them and i love them, although i just got my CEL on. Im not sure if its becuase of the test pipes or my instalation.........i sounds like i did not install them tightly(there is a buzzing sound, i belive the brace is not on tightly) anyhow.....how can i get the CEL to go away? and if i can't what test-pipe can i get to keep the CEL off. I am worried if something goes wrong with my engine i wont konw becuase my CEL is already on.
Old Dec 3, 2005 | 03:40 PM
toykilla's Avatar
toykilla
funny nobody mentions they are different diameters..
Old Dec 3, 2005 | 04:26 PM
thawk408's Avatar
thawk408
Where can I get some o2 sims?
Old Dec 3, 2005 | 05:53 PM
Amiricanmade
wahts that? do i need it for my car?....i never installed one i dont think.
Old Dec 4, 2005 | 08:10 AM
DuPontG35's Avatar
DuPontG35
u need the spark plug defoulers....they work....i only have one set but if i had 2 i know the light would prolly never come on....cause my light goes off for a couple weeks then comes on for a few....goes back and forth by itself....test pipes make that sound so you wont get rid of the hiss or buzz that comes with havin test pipes...
Old Dec 5, 2005 | 12:13 PM
Amiricanmade
i see, i just though i did not tieghten everything right. but i guess its normal. Thanks
Old Dec 5, 2005 | 12:19 PM
ayman350z's Avatar
ayman350z
glad to see u like the test pipes i sold ya
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
