probs with injen sp1986 intake
Old Oct 11, 2005 | 06:41 AM
joseph109783's Avatar
joseph109783
Default probs with injen sp1986 intake
I just recently purchased the injen sp1986 intake and my service engine soon light came on. I disconnected the battery for about 20 min and tryed reseting the ecu that way then I went to technosquares website and printed up a procedure that tells you how to reset the ecu. The procedure that they gave me I tryed it about 10 times and I got nowhere with this thing. If anyone has had this problem can you please give me some advice on how I can fix this or what should I do?
Old Oct 11, 2005 | 06:50 AM
cvt's Avatar
cvt
so i take it disconnecting the battery didn't work???
Old Oct 11, 2005 | 06:58 AM
EdgeOfSanity's Avatar
EdgeOfSanity
you have to disconnect the battery for 24 hours for that method to work. The technosquare way is easy to do, you just have to get the timing down. Use a stopwatch if it helps.
Old Oct 11, 2005 | 09:34 AM
RA11325's Avatar
RA11325
TS method just takes practice, ive done it so many times i can pretty much do it by memory, just take go through and practice each part with a stop watch. After you get it a few times it will become like second nature.
Old Oct 11, 2005 | 09:43 AM
sentry65's Avatar
sentry65
the burninator
i've had the battery method reset SES lights after 8 hours or so, not sure if it did a full reset or not though
Old Oct 11, 2005 | 09:49 AM
cvt's Avatar
cvt
it's such a hassle to reset the ecu..isn't there something we can pull out of the fuse box to make it reset? i had a celica and this is all you had to do...
Old Oct 11, 2005 | 09:55 AM
sentry65's Avatar
sentry65
the burninator
you could get a plug in scanner reader thing and use that to reset the codes for like $80. Of course, you'll still have to wait for it to detect what car you have etc.
Old Oct 11, 2005 | 11:07 AM
the7ferret's Avatar
the7ferret
check for leaks, MAF plugged in, MAF Sensor the correct way, Vacume hose plugged in, thats the most likely cause of a SES Light on an intake, in regards to reseting the ECU, i have done the technosquare many times, just practice the routine a few times to get the timing down before you go to do it on your car.
If it is any of the above most of the tiem the SES light will turn off either immediatly or shortly thereafter.
apex locator
Jul 23, 2021 02:27 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
