Do you need an ecu reflash?
Old Apr 4, 2006 | 02:07 AM
-Amir-'s Avatar
-Amir-
Default Do you need an ecu reflash?
If you do the following mods on a 06 350z Track edition do you need to reflash the ecu?or get a programable ecu like utec or hks f-con?
Crawford Headers,arc induction box+intake tube, motordyne plenum kit,amuse r1 exhaust, and amuse titanium y-pipe(test pipes include)...Do i need a reflash or something of the sort? I havent buy any of the above mods yet...
Old Apr 4, 2006 | 04:26 AM
Vamos_Rafael's Avatar
Vamos_Rafael
buy the mods listed then reflash
and btw the mods listed will cost u at least 5000 usd
Old Apr 4, 2006 | 04:52 AM
jcarp's Avatar
jcarp
if you plan to stay na then i would. it really depends on how much power you want. fi is good but just dont push it too hard with stock block. na is way more reliable. if you get a utec you'll prob see around 10-20 horse power.
Old Apr 4, 2006 | 04:55 AM
-Amir-'s Avatar
-Amir-
I know the price of the mods i listed...thanks for the help...
Old Apr 4, 2006 | 04:58 AM
Welcome to the forum.
You are getting way ahead of yourself here. Mods first. Then concern yourself about a ECU tune.
Old Apr 4, 2006 | 05:36 AM
350Z_LMS's Avatar
350Z_LMS
I have installed NISMO cat back and Crawford HFCs already and have Strup headers and MD MREV+ waiting to be fitted next week. Will I be running my engine (rev-up on 35th) safely after all of these mods? Pinging or detonation are expected? Is a reset all I need or are we looking at UTEC here?
Old Apr 4, 2006 | 05:38 AM
jcarp's Avatar
jcarp
if you run test pipes you especially need a good tune to run properly.
Old Apr 4, 2006 | 08:56 AM
Beeker's Avatar
Beeker
From what I've read, as long as you don't change out the stock cats a tune probably isn't required. Once you install test pipes you run the risk of running very lean. I'm not sure if hi-flow cats cause the same problem.
My air fuel ratio improved when I installed headers. I haven't dynoed again since I installed Borla exhaust and 5/16th spacer. I'm hoping I'm not lean. I don't think I am because I still have a lot of black soot on the Borla tips.
Old Apr 4, 2006 | 09:25 AM
-Amir-'s Avatar
-Amir-
What is the difference between running lean or rich? I guess you can adjust the A/F ratio with a ecu tune?
Old Apr 4, 2006 | 09:29 AM
breed's Avatar
breed
^^running rich is when your getting to much fuel..lean is not enough.
Old Apr 4, 2006 | 11:44 PM
350Z_LMS's Avatar
350Z_LMS
I just have the feeling that breathing and exhaust mods WILL vary the input and parameters the ECU has to deal with and adjust to. The fact that Crawford HFCs don't throw a CEL goes to show things are still in the "norm" for the ECU...but running rich or lean isn't good news...
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
