throttle body bore question
Old Apr 17, 2006 | 06:14 PM
03_Track_Z's Avatar
03_Track_Z
Default throttle body bore question
So I'm getting a crappy beat up throttle body with an intact butterfly plate, and im going to get a friend to use that one to machine out a new one that is slightly larger, and then have my throttle body bored out to fit the bigger plate. are there any things im not covering in this plan? what else is involved in making a big bore throttle body? thanks.
Old Apr 17, 2006 | 10:04 PM
overZealous1's Avatar
overZealous1
making sure you don't go to far, lol. main thing is getting the throttle plate centered correctly.
Old Apr 17, 2006 | 10:26 PM
aalzuhair's Avatar
aalzuhair
Can't anybody find someone with some contacts in let's say China that could cast for us a new 80MM or 85MM or even 90MM TB
Old Apr 18, 2006 | 09:20 AM
Quamen's Avatar
Quamen
Unless you are FI or have a 9000 rpm rev limit anything over stock could be a hinderence for the daily street driver. If you are going for the ultimate NA monster that will have a set power band in the RPM's which you plan to stay in it could be beneficial. Especially with a stroker kit. Otherwise, you would lose low end and gain high end. Maybe a loss in torque due to air velocity.
Old Apr 18, 2006 | 09:26 AM
Cannysage's Avatar
Cannysage
I know someone who ports throttle bodys.. let me know if there's interest, I'll send some info.
Old Apr 18, 2006 | 09:38 AM
aalzuhair's Avatar
aalzuhair
Could you PM me that info. Thanks
Old Apr 18, 2006 | 12:23 PM
ACEMAN's Avatar
ACEMAN
Master
You can give these guys a call, they did mine and i am happy with it. Not sure how much it helps. But it sure did look pretty
http://www.proflowdesign.com/throttlebodies.html
Later
Aceman
Old Apr 18, 2006 | 03:10 PM
aalzuhair's Avatar
aalzuhair
Later
Aceman
Thanks Aceman how much did they port? I think the stock is 70mm did they increase it to 73mm or more.
Thanks,
Az
Old Apr 18, 2006 | 03:17 PM
ACEMAN's Avatar
ACEMAN
Master
The size is 2mm oversize at 72mm, with the inlet enlarged to 78mm.
Turnaround is usually 2 shop days. Shipping time to and from Seattle needs to be considered as well. Performance gains are difficult to quantify due to many different engine preparations, but they say that the rebored throttle body will flow 7% more air than a stock one will.
Jim Hill
Proflow Design
(425) 255-9706
I worked with Jim and spoke to him on the phone many times. He was very easy to work with.
Later
Aceman
Thanks,
Az
Old Apr 18, 2006 | 03:19 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
nice man, did you port the plenum to match it all the way through... ??
Old Apr 18, 2006 | 03:23 PM
ACEMAN's Avatar
ACEMAN
Master
I checked to see if the SSV needed to be ported and everything match up fine. Just needed to shave alittle off of the cork gasket to make it match up.
Later
Aceman
